Thread Number: 10067
Maytag A700 |
Post# 185586 , Reply# 1   1/24/2007 at 19:12 (6,300 days old) by cehalstead (Charleston, WV)   |   | |
i think it is in the transmission....hope someone more knowledgable replies... |
Post# 185594 , Reply# 2   1/24/2007 at 19:42 (6,300 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 185623 , Reply# 3   1/24/2007 at 20:38 (6,300 days old) by bingwsguy (Binghamton NY)   |   | |
Chuck and Kevin....that was my second guess. I understand things only so far, then need the help and advice of others. So it means that any 2 speed Maytag motor that fits will work? Thank You for the help. |
Post# 185633 , Reply# 4   1/24/2007 at 21:00 (6,300 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Yes.... a two speed motor should work fine.... but if your machine originally only had one speed, you will not be able to take advantage of the 2nd speed the motor is capable of. Also you will have to pay close attention to how you wire the motor up (again, only if it's a single speed machine). Good luck with it!!! |
