Thread Number: 10196
Hoover twinnie drain valve questions |
Post# 187830 , Reply# 1   2/1/2007 at 07:02 (6,292 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hi Simon, Congratulations on getting your twinny, What model is it?? Sounds like its half open, could be icky with lime build up, if the pump is genuine and not leaking, try filling the wash tub with a solution of lime away descaler etc... and leave it soaking, the water will flush through the wash/ spin drain areas and will descale the pump, with the solution doing its job turn the pump vale left to right a number times to make sure it gets around all the parts... Then try again, if you do need to change the valve you are right in thinking that large clip needs to snap off, do it with a towel over in case it shoots off...if you need to repair the pump take it out with the pulley attached... Cheers, Mike |
