Thread Number: 103
Maytag A200 Highlander question |
Post# 45307 , Reply# 1   9/18/2004 at 13:20 (7,131 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Remove the chrome trim strip around the top of the machine by turning under one edge at the back with a screw driver. You'll see screws on each side and front of machine holding the top, remove those and you can lift the top up and tip it toward the back of the machine. From there, you'll be able to acess the water inlet system on the left rear corner of the machine. Good luck- Greg |
