Thread Number: 10893
GE Filter Flo Queston |
Post# 197791 , Reply# 1   3/16/2007 at 11:37 (6,244 days old) by spinout (Phoenix)   |   | |
You should be able to lift the top and reach down in between the tubs to grab it. |
Post# 197799 , Reply# 3   3/16/2007 at 11:53 (6,244 days old) by geextrarinse (Hudson Valley, New York )   |   | |
the piece hasn't become wedged in there from the last spin cycle. If it got eaten or chewed up, which is possible, you'll want to replace it - they are easy to find if you have an old junk yard or scrap heap near by. But its important to keep this piece securely inserted into the rubber connetion at the back of the outer tub. Just remember to pull the rubber lip of the splash guard off before you open the top next time. Good luck and let us know how you make out. This is a great machine and will last a long time for you if you're good to it. Most importantly- have fun! Matt |
Post# 197860 , Reply# 4   3/16/2007 at 17:34 (6,244 days old) by exploder3211 ()   |   | |
No its somewhere in the inky void that i can't see. I have another one to replace it with.. Just curious what might happen if i don't replace it?? |
Post# 197893 , Reply# 6   3/16/2007 at 19:14 (6,243 days old) by westytoploader ()   |   | |
Here's the location of the spring clips. You can see where the top is just *slightly* indented in the front. |
Post# 197980 , Reply# 8   3/17/2007 at 08:11 (6,243 days old) by exploder3211 ()   |   | |
Thanks.. Ok between a really skinny person and i we can't find it. We can here it but we can't find it... Yeah i will replace it.. |
Post# 198011 , Reply# 9   3/17/2007 at 11:56 (6,243 days old) by spinout (Phoenix)   |   | |
You need to get it out of there, as you risk the possibility of puncturing the tub boot, which would be decidedly unpleasant. |
Post# 198012 , Reply# 10   3/17/2007 at 12:03 (6,243 days old) by westytoploader ()   |   | |
Yes...did you raise the entire top assembly, THEN feel around for it? |
Post# 198028 , Reply# 11   3/17/2007 at 13:34 (6,243 days old) by goatfarmer (South Bend, home of Champions)   |   | |
