Thread Number: 10953
Fine-Tuning the Maytag A108
Post# 198670   3/20/2007 at 16:30 (6,245 days old) by danemodsandy (The Bramford, Apt. 7-E)
danemodsandy's profile picture
Hello:
I'm extremely happy with my vintage Maytags, an A108 washer and a DE608 dryer. However, the washer is a bit noisier than I'd like, and I think it's correctable.
The basic problem is a brief period of squeaking as it goes into spin. I think new belts will help (there is absolutely no telling how old the current ones are; these machines weren't actually abused, but they sure as shootin' weren't coddled, either). But while I'm under the machine, and inside it, are there any parts that should get lubed. If so, with what? Are there pads that should get replaced? Anything else?
I'm a believer in doing it right and doing it once, so any help on getting things back in really great shape would be appreciated. I've already benefitted in so many ways from everyone's advice- I wouldn't have even attempted to own vintage machines if I didn't have youse guys as a resource!
Thanks in advance!
Post# 198698 , Reply# 1   3/20/2007 at 19:14 (6,245 days old) by pturo (Syracuse, New York)
Try the new belts(ONLY Maytag genuine) first. Then talk about the damper pads in my experience. Good luck.
Post# 198744 , Reply# 2   3/20/2007 at 22:34 (6,245 days old) by danemodsandy (The Bramford, Apt. 7-E)
Thanks, pturo!
I appreciate the heads-up on the pads; I knew I shouldn't use any belts but gen-you-wine Maytag. One question about the pads- do they typically need lubing of some kind, or replacing? Am I going to need a service manual (a good idea on general principles, I grant you)?
Post# 198812 , Reply# 3   3/21/2007 at 13:49 (6,244 days old) by pturo (Syracuse, New York)
The look like nylon felt, and no greasing. They adhere with rubber cement, I think any Maytag parts source carries this "special rubber cement" There are three and they are about 2 inches wide and 6 inches or so long in an arc shape. Their main job is to avoid metal to metal contact when the machine shakes and shimmies and balances out a load.
