Thread Number: 11378
Top ten things we never thought we'd find in Tucson |
Post# 204185   4/15/2007 at 16:09 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204186 , Reply# 1   4/15/2007 at 16:10 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204187 , Reply# 2   4/15/2007 at 16:11 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204188 , Reply# 3   4/15/2007 at 16:12 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204189 , Reply# 4   4/15/2007 at 16:13 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204190 , Reply# 5   4/15/2007 at 16:14 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204191 , Reply# 6   4/15/2007 at 16:15 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204192 , Reply# 7   4/15/2007 at 16:17 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
The motor's start windings shorted-out and are now in contact with the run windings, so running the motor means running the start windings all the time, even though the centrifugal switch works perfectly. If anyone has a motor like this laying around, I'd be infinitely grateful! Otherwise, I'll explore rewinding options... |
Post# 204193 , Reply# 8   4/15/2007 at 16:18 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204195 , Reply# 9   4/15/2007 at 16:19 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204196 , Reply# 10   4/15/2007 at 16:21 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204199 , Reply# 11   4/15/2007 at 16:26 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
A friend of Roger's found this machine in a vintage items store here, and told him about it. Since it was about a block from where I work, I scooted over there (on my lunch half-hour, of course, because I couldn't freaking wait to see what it was). When I asked about the machine (it was part of an apartment "scene" that represented an old kitchen), the owner of the shop said that it was actually from her house (they are out there!), and that it had worked up until it started smoking (ergo, the toasted start windings). Her other-half took it out and intended to toss it, but she realized it'd go great in her store as a prop. Yay to her!! Prior to her own experiences, the machine was owned by a little old lady who never used it (surprise!). Hence, the mint porcelain and racks. The water fill is neat--it showers down from a constant rinse-like twirly on the top, which probably helps remove debris from the backs of the dishes. The drain is gravity for now, but this machine's timer and terminal block support an electric pump, and I will definitely be adding that. So, for now, I need to address the motor--but once that's settled, she should be a fab dishwasher! :-D |
Post# 204206 , Reply# 13   4/15/2007 at 16:58 (6,219 days old) by golittlesport (California)   |   | |
Post# 204207 , Reply# 14   4/15/2007 at 17:08 (6,219 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Thats just a cool find! And PINK; FABOOO PINK; Titty Pink; Maimie Eisenhower Pink too boot! You know I used to have a motor just like that from a Kenmore washer, let me look around if I still have it its yours for shipping. A kenmore motor would work since they were one speed one direction also. In fact any kenmore motor should work. What a great year for Vintage!! jon |
Post# 204209 , Reply# 15   4/15/2007 at 17:09 (6,219 days old) by rickr (.)   |   | |
Post# 204221 , Reply# 16   4/15/2007 at 18:00 (6,219 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Our first house in FL had one! It was yellow. Since everyone ended up in the kitchen, someone always leaned on Big Red. The noise was enough to get them to move. |
Post# 204225 , Reply# 17   4/15/2007 at 18:26 (6,219 days old) by appnut (TX)   |   | |
Nate, that's definitely not the BOL model. The racks here are separete sliding. The bol, the top rack sat on top of the bottom rack and had to be removed (parked on drainboard or countertop) for loading the bottom rack. Next year you'll have this running. This is one of the DWs I was exposed to a lot when I was very young. It was a very popular brand in Dallas.
Post# 204227 , Reply# 18   4/15/2007 at 18:27 (6,219 days old) by appnut (TX)   |   | |
Post# 204231 , Reply# 19   4/15/2007 at 18:41 (6,219 days old) by blackstone (Springfield, Massachusetts)   |   | |
Post# 204263 , Reply# 20   4/15/2007 at 20:15 (6,219 days old) by rogera608s (Tucson,AZ)   |   | |
Just checked the shaft length and diameter......1/2" diameter and the length is 1 and 5/8ths. I thought it looked like the motor in my Blackstone too Fred. |
Post# 204267 , Reply# 21   4/15/2007 at 20:28 (6,219 days old) by hoover1060 ()   |   | |
and its PANK!! Congrats to you! |
Post# 204268 , Reply# 22   4/15/2007 at 20:35 (6,219 days old) by westyslantfront ()   |   | |
Hi Nate. Beautiful machine. Look forward to seeing it and in Bethann or Justin Pink. Congratulations. Ross |
Post# 204271 , Reply# 23   4/15/2007 at 20:38 (6,219 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 204282 , Reply# 25   4/15/2007 at 21:14 (6,219 days old) by swestoyz (Cedar Falls, IA)   |   | |
Dude Nate - what a fantastic save there! The start button is the best part of the machine - no bells, no whistles, just load her up, and push start! And in pink - too cool. The motor shouldn't be much of an issue, looks like a standard belt drive motor - or if you need some help finding a new one, take it down to Grainger, those guys should get you hooked up in no time. Ben |
Post# 204283 , Reply# 26   4/15/2007 at 21:15 (6,219 days old) by westytoploader ()   |   | |
Since it's not a disposable T-frame, could you possibly take the motor to a motor shop to be rewound instead of replacing it? |
Post# 204284 , Reply# 27   4/15/2007 at 21:22 (6,219 days old) by roto204 (Tucson, AZ)   |   | |
And YES, the fan would spin during the drying cycle to quickly air dry the dishes. -- Thanks, Jerry, that's good to know--how fun! :-D I'm also glad to hear that they have good capacity. I love the story about the slighted GE built-in that decided to run on its own. How fun! See? An unused appliance is an unhappy appliance :-D Tucson was a wonderful experience and we all owe a debt of gratitude to Ross and Roger and Nate. Thanks, guys. Love you. -- Aw, thank you so much, Jerry. It was great to get to meet you, and it was definitely our pleasure!! Maybe it is a little thank you from up above for all your wonderful hospitality! -- Thank you, Rich!! :-D If it is, it's one heck of a thank-you!! Thats just a cool find! And PINK; FABOOO PINK; Titty Pink; Maimie Eisenhower Pink too boot! -- ROTF!!!! I think I shall henceforth christen this "Titty Pink," the Mary Kay dishwasher, in your honor :-D Look at how pink it is! It makes the turquoise Kenmore next to it look white! You know I used to have a motor just like that from a Kenmore washer, let me look around if I still have it its yours for shipping. A kenmore motor would work since they were one speed one direction also. In fact any kenmore motor should work. -- Thank you SO much, Jon. I'd really appreciate that. Nate, that's definitely not the BOL model. The racks here are separete sliding. The bol, the top rack sat on top of the bottom rack and had to be removed (parked on drainboard or countertop) for loading the bottom rack. Next year you'll have this running. This is one of the DWs I was exposed to a lot when I was very young. It was a very popular brand in Dallas. -- Then I'll look forward to seeing you load it, Bob!! :-D That's very good to know, and I had forgotten about those stacked racks. Nifty!! And yes, it took us a while to figure out those detergent dispensers. Roger figured out how it worked--GE sure had a penchant for not using solenoids or electricals to dispense the detergent, didn't they? That motor looks almost the same as a Blackstone 350 motor; I saved about a dozen of these. I'll check the specs on my motors. Not sure about the length of the shaft. Yours for the shipping, also. Fred. -- Thank you VERY much, Fred--I very much appreciate your help! I'll have to send you and Jon pies or some such for your troubles! Definitely one of the better-performing impeller dishwashers as well, aside from Kenmore. All of these new finds have me even more excited to get up there next year. -- What shall we eat next year? Oatmeal and peanut-butter to test? :-D I was really surprised to hear that this machine was one of the better performers, and I'm very excited. I don't care about loud. I likes me some results! :-D The electric pump option certainly is icing. I like it when the machine can do the draining itself, and you don't have to reinvent the wheel to get around the gravity drain. Yay!! Yes, Ross, I'll have to arm-wrestle Beth Ann and Justin over this one. And no repainting it--that's porcelain! :-D |
Post# 204287 , Reply# 28   4/15/2007 at 21:34 (6,219 days old) by unimatic1140 (Minneapolis)   |   | |
Hi Nate, wow that is a beautiful find. I know we saw a lot of those GE impellers up at the parts place in Phoenix so you might be able to find a brand new one for it. As for the motor, that look pretty standard. If you find a similar GE motor, but the shaft is different you can take it apart and switch the armatures between the two motors, because the part that is toasted is the stator. |
Post# 204294 , Reply# 30   4/15/2007 at 21:43 (6,219 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Ka-whunk like my KD-12 does. Nate your're gonna love the SAAALAM of the solenoids! Nate that motor must be down at the Cape,next time I am down there I will see if I can find it. Robert has a good tip there you can change out the armature very easily. Jon CLICK HERE TO GO TO jetcone's LINK |
Post# 204305 , Reply# 31   4/15/2007 at 21:58 (6,219 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 204343 , Reply# 32   4/16/2007 at 00:04 (6,219 days old) by appnut (TX)   |   | |
Nate, the steam whafting out of the top of that machine while it's running. Some of my earliest 5-7 y/o memories--complete with 1950s smelling Cascade. This was the same family who had the frog-eyed kemmores (the white/gold faced washer & dark blue/green faced dryer) and then the slant-front westys. This dishwasher served this family well from the time they moved into the brand new house in early to jmid 1950s until they moved into their new built house in 1965 or 1966. and this as a family that grew from 2 kids to 6 before they moved out. So that dishwasher got a lot of use. I remember when we visited on weekends, it was run after each meal. I think the particular installation may have been a gravity drain scenario. I don't really remember the soilenoid klunking when it wwent to drain. But I do remember how it sounded different when the drain closed and water started coming in for the next fill. Dishes baked dry that's for sure. Top rack is kinda awkward to load. You'll have to pay attention now to the Hotpoint PIDs with this style DW. I'll prolly be rinsing dishes b4 I put them in here, or scraping pretty well. No just "dropping" them in like I did with a certain vintage brand of dishwashers during the last two Tuscon visits.
Post# 204399 , Reply# 33   4/16/2007 at 11:08 (6,218 days old) by blackstone (Springfield, Massachusetts)   |   | |
The motor from a Blackstone 350 is very similar to your motor. The shaft measures about 2" from the end of the endplate, and 1/2" diameter, with a flat spot. My motors are 1/3 HP. The screws holding endplates are shorter, so you would have to use yours. Problem is the weight--25 lbs. Parcel Post from here to Left Coast is $31.
Post# 204411 , Reply# 34   4/16/2007 at 11:44 (6,218 days old) by roto204 (Tucson, AZ)   |   | |
Robert -- Yay! Thank you very much for that suggestion--I'll try to scare-up a similar motor. This one was badged for laundry equipment, so maybe it won't be too hard. I'll have to go see about those impellers; I'd love to have a spare or two just in case Something Bad Happens™ to this one. Terry -- You'll have to come visit so you can load it once we get the motor fixed!! :-D Bob -- I love the idea of the steam wafting up out of the top vents. :-) I agree that the top racking on this is odd; I'll keep my eyes peeled for the loading shots, because I can't help but think that the issues posed by this rack are rather similar to our spin-tube--round spray direction; square rack. Huh? Greg -- Well, you know, a housewife like me needs the simplest choices possible. It's like a big button that says, "Clean dishes!" I love it! I also look forward to the day that something F---s up and you have to pull the panel and advance the timer to "OFF" with a butter knife if you don't want to repeat history once the machine's repaired. But that's a minor detail :-D By the way, how are those avocado 'Tags? ;-) Jon--I can't wait to hear the sounds of maelstrom dishwashing! :-D Thanks so much for looking for that motor--I appreciate all your help. :-) Fred--Yay!! E-mail me (nsmarler@hotmail.com) with your mailing address and I'll send you a check. Even if that doesn't work for the dishwasher (and I'd bet it will), it'd be good to have the spare motor. Blackstone, teamed with Hotpoint! That should be cool :-D |
Post# 204415 , Reply# 35   4/16/2007 at 11:49 (6,218 days old) by roto204 (Tucson, AZ)   |   | |
The motor shouldn't be much of an issue, looks like a standard belt drive motor - or if you need some help finding a new one, take it down to Grainger, those guys should get you hooked up in no time. -- Good idea, Ben! Thank you!! :-D I think we should upgrade to, say, a 3/4 HP motor. You know, dishwashing with more power! :-P |
Post# 204460 , Reply# 36   4/16/2007 at 15:02 (6,218 days old) by chachp (North Little Rock, AR)   |   | |
Post# 204497 , Reply# 37   4/16/2007 at 16:20 (6,218 days old) by roto204 (Tucson, AZ)   |   | |
Post# 204504 , Reply# 38   4/16/2007 at 16:29 (6,218 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 204510 , Reply# 39   4/16/2007 at 16:38 (6,218 days old) by roto204 (Tucson, AZ)   |   | |
