Thread Number: 11509
LG Tromm Front Loader |
Post# 206210 , Reply# 2   4/25/2007 at 10:45 (6,209 days old) by ~sudsshane ()   |   | |
I have an LG Tromm front load machine. Use the Permanent Press cycle along with the Water Plus button. This will give you more than enough water to effectively clean your clothes. |
Post# 206703 , Reply# 3   4/27/2007 at 10:33 (6,207 days old) by soapnsuds ()   |   | |
Hmmm, well I'll have to go out to the garage and uncover it an take a look at it for the model number. It's 2.5 years old and does't have a water plus button. :( Thanks and I'll let you know.--James |
Post# 206709 , Reply# 4   4/27/2007 at 11:08 (6,207 days old) by maytagbear (N.E. Ohio)   |   | |
running the cycle, and then running another rinse and spin after? Lawrence/Maytagbear |
Post# 206854 , Reply# 7   4/28/2007 at 00:42 (6,207 days old) by washoholic (San Antonio, TX)   |   | |
My steam washer does fine w/ just a touch of water. The clothes are always clean. Isn’t it about getting the clothes clean, and not about how much water? Anyway try this: With the machine empty set it for an Extra High Spin. (Push power, push the spin speed button until you reach extra high, push start). Let it spin until it gets going pretty fast (there’s another trick to get it to climb up to 1320 rpm right away, but I’m afraid to post it because if you do it with clothes in it; you can ruin it, as the unbalance detector is bypassed). Push power (the power goes off) immediately push power again (the power comes on and the control panel lights up, before it slows down to a stop, turn the knob one time to the right to Cotton/Normal, push water plus, extra rinse, rinse & spin, and then start (you must do all of the steps and push start before the tub stops spinning.) Let the water start to fill and then pause it and add clothes. It will rinse at the highest possible water level which is used in the “tub clean” cycle with an extra high and extra long tumble speed, then spin at extra high, and repeat the process, followed by a 14 minute 1320 RPM spin. It works on the Steam Washer (check my profile for the model #), and may not work on all models. You can always try it and just skip pushing the water plus button if you don’t have it. Let me know if it works. Jeff |
