Thread Number: 11753
GE Filter Flo -Walking all over the place |
Post# 209473 , Reply# 1   5/10/2007 at 21:10 (6,192 days old) by westytoploader ()   |   | |
If you removed the outer tub (which I'm assuming you did) to get the recirculation nozzle out, did you make sure to tighten the tub bolts up? An improperly mounted tub could cause a HUGE problem. |
Post# 209492 , Reply# 2   5/10/2007 at 22:22 (6,192 days old) by exploder3211 ()   |   | |
Yeah i did go back and check the bolts tonight.. It used to walk a little, beacuse it had been dropped at some point, but not this bad.. |
Post# 209503 , Reply# 3   5/11/2007 at 00:31 (6,192 days old) by bobbins (Victoria, BC, Canada)   |   | |
check to see that your cabling balacing support plates are in between the snubber pads (typical for all) Bob |
Post# 209526 , Reply# 4   5/11/2007 at 08:44 (6,192 days old) by exploder3211 ()   |   | |
Ok, the cabinet seems to be twisting a little bit.. |
