Thread Number: 11806
Sometimes you have to be COMBODACIOUS!
Post# 210069   5/14/2007 at 18:54 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
jetcone's profile picture
Yes Combodacious and think outside the OEM parts box!!!
I hit the wall last week and thanks to all your words of encouragement!! We have over come the battleship syndrome.
After getting most of the seals to work properly I came home to find that the "restored" water valve had a S L O W leak to it. Just like my 58 did! Water had backed up the condenser tube and was running across the floor.
A mess!
So not wanting to install another 50 year old valve and face that OR lukewarm water throughout the rest of the house I put on my thinking cap staring at a NEW Maytag water valve.
How could I get that into my Combo and get HOT or WARM water out of it?
Then it hit me: A RELAY A SOLENOID RELAY!!
Off to Radio Shack and $13.99 later I had all the parts I needed.
You wire it in the circuit so that whenever the washer calls for warm water it will call to the COLD water solenoid and then you have the relay activate the HOT solenoid and PRESTO warm water always!!!
I hate thermostatic valves, I hate paying $60 smackers for a 50 year old valve and I hate lukewarm showers and baths at my house.
Now all the problems are solved and I can use a nice $4.99 water valve off ebay that was made only months ago!!!
see the photographic evidence:
Post# 210070 , Reply# 1   5/14/2007 at 18:56 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Both condenser seals are
good to go now as I already did a test load today. No leaks.
The door boot needed a tuck up of the band clamp and that took care of a new little drip too.
Post# 210071 , Reply# 2   5/14/2007 at 18:58 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
A money shot
Here is the first successful load that was washed and dried today.
ADME let me have the afternoon off YAY!
Post# 210072 , Reply# 3   5/14/2007 at 19:02 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
The dry cycle
As you know the hot box leaked like a sieve when I first tested this machine.
I used JB Industro Weld and Hi Temp Silcone and prayed to the washer gods in the sky and drains!!
IT WORKED see the photographic evidence!
I also tested the temp range with my meter and found the box only reached 230-240 degrees WELL BELOW the 650 degrees of the JB Weld and WELL below the 600 degrees of the silicone
Post# 210073 , Reply# 4   5/14/2007 at 19:04 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
You can see the smoke rising
off the Heater Box after all the oils and penetrants are burned off .
Post# 210075 , Reply# 5   5/14/2007 at 19:10 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
In the process I also got
rid of the nasty deadly asbestos gaskets so now I have a mint 50 dryer with no deadly asbestos YAY!
BEFORE
Post# 210076 , Reply# 6   5/14/2007 at 19:11 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
AFTER
and away goes trouble down the drain
Post# 210077 , Reply# 7   5/14/2007 at 19:11 (6,181 days old) by laundryshark (Cedar Rapids, Iowa)
After You Get a Well-Deserved Rest...
Would ya mind sharing a video demo of your restored Bendix? Sounds like you went through the wringer to get her working up to snuff. Big Congrats on overcoming all those annoying leaks and other issues. Many Thanks.--Laundry Shark
Post# 210078 , Reply# 8   5/14/2007 at 19:13 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
I would but I need to find a video camera
I dig around my friends.
jon
Post# 210079 , Reply# 9   5/14/2007 at 19:15 (6,181 days old) by tlee618 ()
I'm so proud of you Jon!!! I knew that you could do it. Can't wait to see it when you have it all installed in its new spot.
Post# 210085 , Reply# 10   5/14/2007 at 19:25 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Thank you Terry
now I can walk away from wash day just like those ladies in the 1930's ads!!
Post# 210088 , Reply# 11   5/14/2007 at 19:36 (6,181 days old) by appnut (TX)
appnut's profile picture
Jon, congratulations. I knew you could do it!! Good ol' Yankee (literally and said lovingly) ingenuity comes to the forefront and saves the day!! YEE HAW!! And see, everyone is so proud of you and thrilled with your success, you earned the Good Housekeeping Seal of Approval!! What a man!!! Bob
Post# 210095 , Reply# 12   5/14/2007 at 20:04 (6,181 days old) by mickeyd (Hamburg NY)
mickeyd's profile picture
Perfect creases on the t-shirt, Jon!
Such grooming !
And Al is an excellent photographer.
Post# 210109 , Reply# 13   5/14/2007 at 21:59 (6,181 days old) by golittlesport (California)
golittlesport's profile picture
you are combobulous, Jon!!!!
Post# 210141 , Reply# 14   5/15/2007 at 06:30 (6,181 days old) by unimatic1140 (Minneapolis)
Beautiful restoration work Jon, brings a tear to my eye! I love JB Weld as well, I always carry a couple of tubes with me in my purse just in case.
Post# 210143 , Reply# 15   5/15/2007 at 06:58 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
I love that Robert
in your purse good for you!
I must make a bag with Felix on it for my bag of tricks.
Thank you Rich now you'll HAVE to come out and do laundry!
Mikey I didn't even notice my T was creased thank you and thanks to Bendix auto dry.
Alitle closer to a wash-in now folks!
Post# 210144 , Reply# 16   5/15/2007 at 07:05 (6,181 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Oh and Bob
I'll have some nice close ups for you once I get the top back on and it is in service!! Thanks Jon
Post# 210147 , Reply# 17   5/15/2007 at 07:17 (6,181 days old) by gansky1 (Omaha, The Home of the TV Dinner!)
gansky1's profile picture
Wow! Look at that butt on that Bendii-Boy! You'll be in the AW.org calendar for sure...
Nice work on the combo, do you have a wiring diagram and parts-list for your water valve relay? It might be helpful to post that for collectors in future civilizations to get their excavated Bendix combos (and any machine with a pesky water valve) running again.
Post# 210162 , Reply# 18   5/15/2007 at 09:16 (6,181 days old) by veg-o-matic (Baltimore, Hon!)
Jetcone:
veg-o-matic's profile picture
He's Combolicious!
Post# 210182 , Reply# 19   5/15/2007 at 11:33 (6,181 days old) by tlee618 ()
Damn boy, you are sure looking good these days!!! I know you will make the calendar cut for sure!!
Post# 210190 , Reply# 20   5/15/2007 at 12:21 (6,181 days old) by peterh770 (Marietta, GA)
peterh770's profile picture
Oh..My...God...Becky...
Look at the size of his...
Post# 210195 , Reply# 21   5/15/2007 at 13:20 (6,180 days old) by roto204 (Tucson, AZ)
roto204's profile picture
...thirty-three-inch Bendix.
Dude, that is so huge. I've never seen bigger than 29.
Post# 210211 , Reply# 22   5/15/2007 at 15:52 (6,180 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)
foraloysius's profile picture
I can only say one thing: supercalifragilistic alandjonwashcomboveryprecious
Post# 210250 , Reply# 23   5/15/2007 at 19:06 (6,180 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Oh Louis thats cool
Al appreciates your attentions!
So Peter you like my 33 inch Combo? Well thank YOU very much, it was alot of hard work!
Jon & Al
Post# 210258 , Reply# 24   5/15/2007 at 19:37 (6,180 days old) by brettsomers ()
good, I am not the only one who noticed Jetcones shapely @ss! spank!
Post# 210260 , Reply# 25   5/15/2007 at 19:41 (6,180 days old) by westytoploader ()
Jon, awesome news, glad to see it washing away! The chain-drive timer is TRES cool...I didn't know they were like that. I'll have to remember that relay trick you did when I have to change a water valve.
Good luck on the remaining restoration work!
Post# 210436 , Reply# 26   5/16/2007 at 20:13 (6,179 days old) by appnut (TX)
Jon, actually I'd prefer your top not be on ;-)
Post# 210438 , Reply# 27   5/16/2007 at 20:20 (6,179 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Not yet you don't , I need
some more gym time for that BUT Al is in great shape as you can see, not an ounce on him that shouldn't be there.
Thanks for all the compliments--mostly on the Combo.
Jon
