Thread Number: 11828
Frigidaire Two-Way Tumble Dryer |
Post# 210262   5/15/2007 at 20:07 (6,184 days old) by exploder3211 ()   |   | |
Has any one ever seen one of these??? It looks so neat from the owners manual... Hmmm.. Wonder why it never caught on CLICK HERE TO GO TO exploder3211's LINK |
Post# 210264 , Reply# 1   5/15/2007 at 20:08 (6,184 days old) by exploder3211 ()   |   | |
Link did not work.. Try this and click on second model number.. Wait a few sec. for book.. I am soo curious CLICK HERE TO GO TO exploder3211's LINK |
Post# 210267 , Reply# 2   5/15/2007 at 20:19 (6,184 days old) by toggleswitch (New York City, NY)   |   | |
~Wonder why it never caught on. It probably never caught on in the US in that our larger dryer drums naturally tend to tangle and ball-up less then other country's smaller ones. The feature is therefore of limited utlity here. I'm guessing that two-way tumbling is a change of engineering and and additional motor, something that may not be worth re-tooling a factory to make if the reulting feature provides a very limitied (if any) benefit in our machines. My Italian-made compact 110v portable Combo-o-matic (years ago) had a reverse tumbling dryer. It helped I'd say due to tiny drum. |
Post# 210284 , Reply# 3   5/15/2007 at 22:48 (6,184 days old) by frigilux (The Minnesota Prairie)   |   | |
My 1st generation Frigidaire/Electrolux dryer (1996; paired with their first FL'er) had a 5.7 cubic foot drum and it reverse-tumbled. Mine was gas, so it reversed only about every 6 or 7 minutes. The electric version reversed more often. I didn't notice less wrinkling---in fact, I'd just come off a huge KitchenAid dryer, so the Frigidaire's drum seemed tiny and wrinkle-inducing by comparison---but sheets and tablecloths didn't ball up, which was nice. |
Post# 210372 , Reply# 5   5/16/2007 at 12:26 (6,183 days old) by accapp ()   |   | |
The reversing feature requires a DC drive motor and a special control board. Most of my customers who have one don't even realize it is a reversing dryer. It really doesn't make a difference in drying performance. |
Post# 210395 , Reply# 7   5/16/2007 at 15:04 (6,183 days old) by wash&where? ()   |   | |
Frigidaire stopped manufacturing these dryers because they were trouble prone. The motors they used failed more frequently than non reversing. That is why they are gone. |
Post# 210396 , Reply# 8   5/16/2007 at 15:04 (6,183 days old) by wash&where? ()   |   | |
Post# 210398 , Reply# 9   5/16/2007 at 15:13 (6,183 days old) by panthera (Rocky Mountains)   |   | |
You don't have to go the DC route, a simple, standard reversing AC motor (like most US TLs have) will do just fine. There are many still being built and sold in just that form here in Europe today. Nor is it all that hard to modify the belt tensioner to run in both directions. There are really only three changes necessary. The belt tensioner, the motor and the timer - you want a bit of a pause in there before the drum reverses. But why bother? US dryers, unless horribly overloaded run just fine, their big drums prevent tangling pretty well. There is another reason. Many US dryers do have reversing motors...but when the motor is in "reverse" a slip-clutch on the motor shaft doesn't drive the drum belt. The blower and heat runs and with a simple rack, the dryer is optimal for drying sweaters and things which must not be tumbled. I worry about the continuous heating elements in early Frigimores...got my folks one of the very last of the old series this winter and they use those horrid dryer sheets. No way to get anyone to believe me that they are dangerous. Anyone here have any good links showing the horrors these things can cause? |
Post# 210426 , Reply# 10   5/16/2007 at 18:51 (6,183 days old) by toggleswitch (New York City, NY)   |   | |
`Many US dryers do have reversing motors...but when the motor is in "reverse" a slip-clutch on the motor shaft doesn't drive the drum belt. The blower and heat runs and with a simple rack, the dryer is optimal for drying sweaters and things which must not be tumbled. Oooh i was unaware of this. Andyone have any brand names, year of vingtage or modern links as an example? |
Post# 210488 , Reply# 11   5/17/2007 at 07:06 (6,183 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 210740 , Reply# 12   5/18/2007 at 19:44 (6,181 days old) by lightedcontrols ()   |   | |
has reverse tumbling and it works VERY well! (It's an AC motor) Mark |
Post# 210823 , Reply# 13   5/19/2007 at 10:22 (6,180 days old) by panthera (Rocky Mountains)   |   | |
Has this system too, which is how I came to know of it. Replaced their timer after some thirty years of use...but neither the belt nor the tensioner nor the slip clutch nor the AC motor were in that bad of condition. When I asked this week, they did recall that the dryer had eaten through two sets of belts and clutches under warranty...then things had run well from the early 80's on. So maybe there were problems at the beginning? I do know that neither belts, nor motors nor tensioners are a common problem with reversing dryers in Europe. |
