Thread Number: 1185
Maytag A208 |
Post# 56017 , Reply# 2   2/4/2005 at 23:43 (7,013 days old) by swestoyz (Cedar Falls, IA)   |   | |
The part that spins is the housing and counter weight for the tranny -- and yes, it is quite scarry to see it spin! It spins at the normal rate the would basket spin, which I'm guessing is around 400-700 rpm on the normal cycle. The bleach dispenser you speak of is the same resevoir on my A806S, which is a model mentioned in your Service Master. If you have the same book I do (the red one, which only list early models, with the 806 and 906 being the latest, and not the Ax08 models), it only shows the early system. I'm no expert (even though I'd like to be!) on the Maytags, but from what I have observed, the A606 and the A208 appear to be like, having the same functions. And yes the bleach simply drains from the little tube straight into the outer basket. Hope some of this helps --- Ben |
Post# 56029 , Reply# 3   2/5/2005 at 06:36 (7,012 days old) by goatfarmer (South Bend, home of Champions)   |   | |
