Thread Number: 11884
Miss Norge Dispensomat Finds Her Mate...... |
Post# 211101 , Reply# 1   5/20/2007 at 14:00 (6,179 days old) by filterflo (Chicago Area)   |   | |
Norge logo........and hi profile console.......This dryer is just as fabulous as the washer and has features that make it quite unique....... |
Post# 211102 , Reply# 2   5/20/2007 at 14:01 (6,179 days old) by filterflo (Chicago Area)   |   | |
Left side of the console and controls....... |
Post# 211103 , Reply# 3   5/20/2007 at 14:02 (6,179 days old) by filterflo (Chicago Area)   |   | |
Dial and Fabric Selector......... |
Post# 211104 , Reply# 4   5/20/2007 at 14:03 (6,179 days old) by filterflo (Chicago Area)   |   | |
More controls, Dial A Heat selectors........ |
Post# 211105 , Reply# 5   5/20/2007 at 14:06 (6,179 days old) by filterflo (Chicago Area)   |   | |
Fabric Cycle Indicator Drum. This drum rotates to different settings when the Fabric Dial is turned.......Then the user turns the Dial A Heat knobs to correspond to the "DOTS" on the Fabric Drum........ |
Post# 211106 , Reply# 6   5/20/2007 at 14:07 (6,179 days old) by filterflo (Chicago Area)   |   | |
Norge Time Line indicator, thermometer style.........in RED |
Post# 211107 , Reply# 7   5/20/2007 at 14:08 (6,179 days old) by filterflo (Chicago Area)   |   | |
Nylons and Lingerie cycle...... |
Post# 211108 , Reply# 8   5/20/2007 at 14:09 (6,179 days old) by steved (Guilderland, New York)   |   | |
Is that the dryer they used to advertise with the hairdryer attachment? Is it all porcelain? Steved |
Post# 211109 , Reply# 9   5/20/2007 at 14:11 (6,179 days old) by filterflo (Chicago Area)   |   | |
Automatic Wash N Wear and Blankets...... |
Post# 211111 , Reply# 10   5/20/2007 at 14:13 (6,179 days old) by filterflo (Chicago Area)   |   | |
Knit Woolen cycle. Notice the No Tumble Feature. This dryer has Stop N Dry. When you select Stop N Dry, the drum does not turn but the fan continues to blow air/heat thru the drum......... |
Post# 211112 , Reply# 11   5/20/2007 at 14:15 (6,179 days old) by filterflo (Chicago Area)   |   | |
Delicate cycle. Again, notice the "DOTS" where the user is supposed to turn the knobs to! |
Post# 211113 , Reply# 12   5/20/2007 at 14:16 (6,179 days old) by filterflo (Chicago Area)   |   | |
Fluffing, Pillows, Draperies......... |
Post# 211114 , Reply# 13   5/20/2007 at 14:17 (6,179 days old) by filterflo (Chicago Area)   |   | |
Regular cycle........... |
Post# 211115 , Reply# 14   5/20/2007 at 14:18 (6,179 days old) by filterflo (Chicago Area)   |   | |
Cottons, Linens, 8-9lb Load! |
Post# 211116 , Reply# 15   5/20/2007 at 14:19 (6,179 days old) by filterflo (Chicago Area)   |   | |
Stop N Dry. By simply turning this knob, either with the dryer on or off, the No Tumble feature takes effect. A useful feature for the tennis shoes! |
Post# 211117 , Reply# 16   5/20/2007 at 14:20 (6,179 days old) by filterflo (Chicago Area)   |   | |
Cyclops style indicator light........ |
Post# 211118 , Reply# 17   5/20/2007 at 14:21 (6,179 days old) by filterflo (Chicago Area)   |   | |
Green Indicator Light, the dryer is ON ! ! |
Post# 211119 , Reply# 18   5/20/2007 at 14:22 (6,179 days old) by filterflo (Chicago Area)   |   | |
This is the gas version. On the top of the dryer is this door for access to the pilot light and gas burner........ |
Post# 211120 , Reply# 19   5/20/2007 at 14:22 (6,179 days old) by filterflo (Chicago Area)   |   | |
Gas burner........... |
Post# 211121 , Reply# 20   5/20/2007 at 14:24 (6,179 days old) by filterflo (Chicago Area)   |   | |
The heat is regulated thru this assembly, attached to a bowden cable, that is attached to the Dial A Heat Selector. |
Post# 211122 , Reply# 21   5/20/2007 at 14:24 (6,179 days old) by filterflo (Chicago Area)   |   | |
Push Button to open the door......... |
Post# 211123 , Reply# 22   5/20/2007 at 14:25 (6,179 days old) by filterflo (Chicago Area)   |   | |
Norge Logo in the lower front corner of the dryer........ |
Post# 211125 , Reply# 23   5/20/2007 at 14:26 (6,179 days old) by filterflo (Chicago Area)   |   | |
A few shots of the matching Norge Dispensomat Washer...... |
Post# 211126 , Reply# 24   5/20/2007 at 14:26 (6,179 days old) by filterflo (Chicago Area)   |   | |
Dispensomat control panel |
Post# 211127 , Reply# 25   5/20/2007 at 14:27 (6,179 days old) by filterflo (Chicago Area)   |   | |
Dispensomat panel, open......... |
Post# 211128 , Reply# 26   5/20/2007 at 14:28 (6,179 days old) by filterflo (Chicago Area)   |   | |
Norge Dispensomat Clock....... |
Post# 211129 , Reply# 27   5/20/2007 at 14:29 (6,179 days old) by filterflo (Chicago Area)   |   | |
Together as a matched set........ |
Post# 211130 , Reply# 28   5/20/2007 at 14:29 (6,179 days old) by filterflo (Chicago Area)   |   | |
Norge Hamper Door, in loading position........ |
Post# 211131 , Reply# 29   5/20/2007 at 14:30 (6,179 days old) by filterflo (Chicago Area)   |   | |
Norge 3Way Door, in Normal position....... |
Post# 211132 , Reply# 30   5/20/2007 at 14:31 (6,179 days old) by filterflo (Chicago Area)   |   | |
Norge Hamper Door, in fully open position. To reach those hard to find items in the back of the drum........ |
Post# 211133 , Reply# 31   5/20/2007 at 14:32 (6,179 days old) by filterflo (Chicago Area)   |   | |
Drum light, located at the bottom of the inside front panel. This dryer also has an ozone bulb in the back of the drum..... |
Post# 211138 , Reply# 34   5/20/2007 at 15:06 (6,179 days old) by pdub (Portland, Oregon)   |   | |
Post# 211152 , Reply# 35   5/20/2007 at 15:33 (6,179 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 211153 , Reply# 36   5/20/2007 at 15:34 (6,179 days old) by golittlesport (California)   |   | |
Post# 211155 , Reply# 37   5/20/2007 at 15:39 (6,179 days old) by peteski50 (New York)   |   | |
Post# 211157 , Reply# 38   5/20/2007 at 15:41 (6,179 days old) by steved (Guilderland, New York)   |   | |
Wow, I didn't realize that the Norge had a delay start option back in the day!! If this is a DG-500, it retailed for $359.95. The washer AWD-502 sold for $399.95. Not a big difference in prices between the washer and dryer, much like today. SteveD |
Post# 211159 , Reply# 39   5/20/2007 at 15:45 (6,179 days old) by sharples ()   |   | |
What an amazing pair... i'm super excited for you!! |
Post# 211166 , Reply# 40   5/20/2007 at 16:04 (6,179 days old) by appnut (TX)   |   | |
Post# 211171 , Reply# 41   5/20/2007 at 16:22 (6,179 days old) by kenmore58 (Rhode Island)   |   | |
Post# 211174 , Reply# 42   5/20/2007 at 16:25 (6,179 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 211176 , Reply# 43   5/20/2007 at 16:29 (6,179 days old) by spiralator60 (Los Angeles)   |   | |
Congratulations! You've got a beautiful machine. Where is the lint filter located? |
Post# 211189 , Reply# 44   5/20/2007 at 16:57 (6,179 days old) by polkanut (Wausau, WI )   |   | |
Post# 211193 , Reply# 45   5/20/2007 at 17:04 (6,179 days old) by abcomatic (Bradford, Illinois)   |   | |
Jimmy, How cool is this! Love the pair; looks really good. Gary |
Post# 211196 , Reply# 46   5/20/2007 at 17:22 (6,179 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 211201 , Reply# 47   5/20/2007 at 18:03 (6,179 days old) by appnut (TX)   |   | |
Jimmy, I could see dots on the dial-a-fabric indicating high or low heat, but never saw a fabric type that indicated a medium heat, or did I miss something? Looks like the link filter door at the bottom of the cabinet is missing? The drum light on our '64 Norge Wrinkle-Out dryer was in thes ame location.
Post# 211202 , Reply# 48   5/20/2007 at 18:10 (6,179 days old) by frontaloadotmy (the cool gay realm)   |   | |
The only thing better than having a dispensing system that adds at exactly the correct instant, is the exact matching companion dryer!!!!! |
Post# 211204 , Reply# 49   5/20/2007 at 18:11 (6,179 days old) by scoots (Chattanooga TN)   |   | |
Post# 211210 , Reply# 50   5/20/2007 at 18:53 (6,179 days old) by trainguy (Key West, FL)   |   | |
Post# 211211 , Reply# 51   5/20/2007 at 18:54 (6,179 days old) by rickr (.)   |   | |
Post# 211218 , Reply# 52   5/20/2007 at 19:16 (6,179 days old) by sambootoo (Moody, AL)   |   | |
Now those are some machines!! Congratulations on a great matched set. |
Post# 211219 , Reply# 53   5/20/2007 at 19:19 (6,179 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 211221 , Reply# 55   5/20/2007 at 19:45 (6,179 days old) by bajaespuma (Connecticut)   |   | |
Post# 211229 , Reply# 56   5/20/2007 at 20:02 (6,179 days old) by 48bencix (Sacramento CA)   |   | |
What a great picture presentation. Thanks for the Sunday Afternoon treat!! The Borg-Warner quality is evident. Martin |
Post# 211231 , Reply# 57   5/20/2007 at 20:05 (6,179 days old) by westyslantfront ()   |   | |
Hi Jimmy. Congratulations on finding a matching dryer. You have a beautiful set of Norges. Ross |
Post# 211249 , Reply# 58   5/20/2007 at 20:50 (6,179 days old) by northwesty (Renton, WA)   |   | |
What is the story behind it? -- how did you find it. Looks great together |
Post# 211255 , Reply# 59   5/20/2007 at 22:04 (6,178 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 211256 , Reply# 60   5/20/2007 at 22:05 (6,178 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 211262 , Reply# 61   5/20/2007 at 22:22 (6,178 days old) by spinout (Phoenix)   |   | |
Simply awesome. |
Post# 211296 , Reply# 62   5/21/2007 at 07:03 (6,178 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 211312 , Reply# 64   5/21/2007 at 08:42 (6,178 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 211322 , Reply# 65   5/21/2007 at 09:27 (6,178 days old) by peterh770 (Marietta, GA)   |   | |
Post# 211340 , Reply# 66   5/21/2007 at 11:57 (6,178 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Jimmy ... What a FANTASTIC set!! Wow ... you must have been absolutely thrilled to match them up!! Those consoles are incredible; so stately looking!! :-) CONGRATULATIONS!! Geoff |
Post# 211347 , Reply# 67   5/21/2007 at 13:00 (6,178 days old) by washerlover (The Big Island, Hawai’i)   |   | |
Post# 211351 , Reply# 68   5/21/2007 at 13:53 (6,178 days old) by jeb (Mansfield Ohiio)   |   | |
I remember that washer from when I visited befor, I thought it was cool by itself- now with the matching dryer it look even better ! The dryer with the specialty dialing cycles reminds me of the Westinghouse "computer " control. Jeff |
Post# 211390 , Reply# 69   5/21/2007 at 18:03 (6,178 days old) by fridgiman ()   |   | |
Hey Jimmy How cool is that ! I'm really happy that you found that matching dryer. You truly are the King-of-the-Matched-Sets. Jim |
Post# 211403 , Reply# 70   5/21/2007 at 19:11 (6,178 days old) by bajaespuma (Connecticut)   |   | |
Post# 211445 , Reply# 72   5/21/2007 at 21:25 (6,177 days old) by appnut (TX)   |   | |
Tomturbomatic, "interesting" about the small to large flame control on the older TimeLines. We had that dryer until I was 10.75 years old, but I odn't recall seeing that under the top lid that gave access to the flame lighting. Maybe it was better I dind't know about it, lol. I have to admit, I always wondered why there wasn't a temperature control on ours, but I thinnk ours was a BOL cuz it didn't have a light in it the panel. Our '64 Norge dryer, the top'n'dry feature control was on the control panel, it was a sliding lever that mirrored the variable water level position on the washer.
Post# 211647 , Reply# 73   5/22/2007 at 17:10 (6,177 days old) by customline (pennsylvania)   |   | |
Both units look great together. What an incredible find. I hope you have many years of enjoyment with your set of Norges. |
Post# 211722 , Reply# 75   5/22/2007 at 21:38 (6,176 days old) by spats ()   |   | |
Wow Jimmy, beautiful machines there! Congrats!! |
Post# 212063 , Reply# 77   5/24/2007 at 20:11 (6,175 days old) by angus (Fairfield, CT.)   |   | |
When I look at that clock, I have an overwhelming urge for a Dr. Pepper.... |
Post# 212070 , Reply# 78   5/24/2007 at 20:58 (6,175 days old) by drmitch ()   |   | |
Wow, what a cool set Jimmy! Glad you found the mate to the dispenseomat. |
Post# 212197 , Reply# 79   5/25/2007 at 11:41 (6,174 days old) by tomturbomatic (Beltsville, MD)   |   | |
Sorry, I meant to say continuously variable heat input as opposed to the click position dials with settings such as Air Fluff, Low & Super Fast. Early bol Timelines must have had only had one heat input level. |
Post# 212285 , Reply# 80   5/25/2007 at 22:17 (6,173 days old) by tlee618 ()   |   | |
Such a beautiful set Jimmy with their console lights glowing. Where did you find this beauty and do you know any of its history? Thanks for sharing. |
Post# 212339 , Reply# 81   5/26/2007 at 08:02 (6,173 days old) by trainguy (Key West, FL)   |   | |
Post# 212346 , Reply# 82   5/26/2007 at 08:42 (6,173 days old) by paulg (My sweet home... Chicago)   |   | |
I love the electric clock. ... Just think of it... with a clock on the unit you can time the drying cycle TO THE SECOND! While the darling hubby is asleep, you can set the dryer to dry clothes while you run out for a quick round of Canasta with the girls. If your hubby is a cheatin' man, you can set the dryer to dry a load of gasoline-soaked laundry while he slumbers away. |
Post# 212389 , Reply# 83   5/26/2007 at 13:03 (6,173 days old) by paulg (My sweet home... Chicago)   |   | |
My last post makes no sense as the clock is on the washer. I've got nothing funny to say now. Perhaps General-Time or Telechron had a big sale on clock mechs and the Norge engineers said "Hell, let's put a clock on that there washer!" Did clock-happy Norge put clocks on other items of that period-like water-heaters or dehumidifiers? Does the washer have a "snooze-bar"? (I can't unload the washer right now.. give me ten more minutes) |
Post# 212397 , Reply# 84   5/26/2007 at 14:25 (6,173 days old) by mickeyd (Hamburg NY)   |   | |
I guess you got the washer a few years back, before i joined. Did you take fantastic fotos also, of the washer then ; and if so, could you tell me where to find them. I'd so love to know what it says on the clock, and to see the agitator. Never seen control panels so high on a washer/dryer. Lit up at night, it looks like an older huge stove, so way up and all clocked. Beautiful ! |
