Thread Number: 11941
50 YEARS CLEAN |
Post# 211805   5/23/2007 at 08:25 (6,180 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
I opened up the 58 Econo Model Combo last nite to replace gaskets and found a spotless inside. See how clean it is this is because it was used as a WASHER and a DRYER not just one or the other. Things should be used for their natures, this machine was desinged to be both. See the photographic evidence below. |
Post# 211806 , Reply# 1   5/23/2007 at 08:26 (6,180 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 211807 , Reply# 2   5/23/2007 at 08:27 (6,180 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 211813 , Reply# 3   5/23/2007 at 08:57 (6,180 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 211832 , Reply# 4   5/23/2007 at 10:24 (6,180 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 211848 , Reply# 5   5/23/2007 at 11:57 (6,180 days old) by roto204 (Tucson, AZ)   |   | |
That's incredible, Jon, and it sure does underscore your point. I was thinking the other day that it'd be fun to have a combo and a top-loader in my laundry room (only room for two, alas--travesty!), but it's obvious that cheating and using the combo as a part-time dryer only would wreck the yin-yang balance between washer and dryer. I wonder if you could use it as a dryer occasionally if you made sure to run full wash-dry cycles in the interim, or if the cleaning of the mechanism is so dependent on constant washer-dryer runs that you'd upset the delicate balance if you did so. |
Post# 211851 , Reply# 6   5/23/2007 at 12:10 (6,180 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
From what I have read in the ancient doctrine the design was dependant on frequent washing as the spray inside the condenser tube and heater box is not very aggressive its more like a splash than a spray. Do you see in the first photo of the blower box just behind the turquoise wire there is a smooth corner in there? That is where the water hits and divides to the heater box and condenser tube. You are looking down the condenser tube. So it's not a sharp corner its very rounded. I would love to see the fill in action there. jon |
Post# 211855 , Reply# 7   5/23/2007 at 12:21 (6,180 days old) by roto204 (Tucson, AZ)   |   | |
