Thread Number: 121
DVD arrived today ! |
Post# 45463   9/20/2004 at 16:51 (7,150 days old) by jmirawm (Barling Arkansas)   |   | |
YAY ! The DVD of "the pig" arrived in the Mail today. Cant wait to WATCH IT ! I will probably have to wait till tomorrow:( Kind of busy with things today. Thanks ROBERT ! |
Post# 45472 , Reply# 1   9/20/2004 at 19:00 (7,150 days old) by PeterH770 (Marietta, GA)   |   | |
Pig, pig, pig, pig, pig!!! Could a washer possibly use more water? Better watch the water level in local rivers, streams and lakes when you start doing laundry in this machine! Robert, is there a missing or bad gasket between the agitator and its top? And the pig has a problem trying to digest jeans it seems. Like the uneven stroke of the agitator isn't enough to pull them under, but it is enough to move the rest of the load around it. Very interesting! Thanks so much for making this! -ph |
Post# 45473 , Reply# 2   9/20/2004 at 19:09 (7,150 days old) by jasonl (Cookeville, TN)   |   | |
Yay! I got mine today, had to put towels around the television because ofthe water splashing out of the screen. Thanks you Robert! Hope to see more Washer Exotica from your collection. |
Post# 45484 , Reply# 4   9/20/2004 at 20:45 (7,150 days old) by Unimatic1140 (Minneapolis)   |   | |
Hi Guys, I was wondering if the first round of DVD's would start arriving today! YAY. Isn't that machine a pig, they should have never made such a monster! It just keeps on filling and filling and filling. Then all that thrashing and splashing after that. I can't wait to hear what other people have to say about our little Arnold Ziffle of the Laundry. |
Post# 45516 , Reply# 6   9/21/2004 at 08:58 (7,149 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 45519 , Reply# 7   9/21/2004 at 10:25 (7,149 days old) by Unimatic1140 (Minneapolis)   |   | |
Hi Peter, no it has a float in the outer tub. In the video, you can see all the extra water that has to overflow (at least a couple of gallons) in order to trip the switch. The Philco works the same way, but Philco was smart enough to place the switch down in a sump so it only takes 1/4 of a gallon overflow to start agitition in the Philco. The '51 GE is even worse it takes about 3.5 to 4 gallons to get it started! The drive block is a hex drive block. |
Post# 45523 , Reply# 8   9/21/2004 at 11:42 (7,149 days old) by jasonl (Cookeville, TN)   |   | |
Doesn't the Frigidaire Rollermatic machines have a water level switch in the bottom of the outer tub to sense the tub is full or is it timed? |
Post# 45525 , Reply# 9   9/21/2004 at 12:16 (7,149 days old) by lesto (Atlanta)   |   | |
I didn't realize the 51 GE was such a water hog too. But my mon's old 59 was the same way. It took quite alot of overflow to get it started. Probably the same amount. I hope you make a dvd of the 51 GE soon! |
Post# 45531 , Reply# 10   9/21/2004 at 15:05 (7,149 days old) by PeterH770 (Marietta, GA)   |   | |
Only the TOL Rollermatics toward the end of their run (1967-1969?) had metered fill. For every 10 parts of water that entered the washtub, 1 part was diverted to the outer tub. That 1 part went into a special sump that had a variable water level pressure switch attached. The user controlled the amount of water with a knob on the control panel. This differs from the GE, Philco and now Wizard in that a certain amount of water had to fill and overflow the wash tub to trigger the water pressure switch. The user has no control over this system -- except for either setting a shorter fill time or by pressing a button on the control panel to cut off the water and start agitation. I think only certain WP/KM machines had an actual float in the outer tub. Then there is the float in the Maytag agitator. -ph |
Post# 45580 , Reply# 11   9/22/2004 at 10:38 (7,148 days old) by jasonl (Cookeville, TN)   |   | |
Right, the early KM/WP had a toilet bowl type float that triggers agitation when the water reaches a certain level. The float on the old Maytag hits a switch on the lid. |
Post# 45668 , Reply# 12   9/23/2004 at 21:38 (7,147 days old) by DADoES (TX, U.S. of A.)   |   | |
Interesting and surprising that it has rather poor rollover. I imagine that's mostly because of the indexing, but it must be rough on clothes! With all that water and overflowing, it's also surprising that there's a touch of suds left in the rinse. And that loooonng coasting to a stop from spin! Is there a balance ring of some sort on the basket that adds intertia or is it just an effect of not having a brake? Is it a two-speed machine? I don't recall from the console pictures. It'd be cool on future videos to show a bit of the various speeds on multi-speed machines. Not an entire cycle at all the speeds, but switching speeds (if possible) during a cycle to show the difference. |
Post# 45674 , Reply# 13   9/23/2004 at 22:05 (7,147 days old) by Unimatic1140 (Minneapolis)   |   | |
Hi Glenn, glad you enjoyed the video. Yes there is a balance ring on top of the tub, its the yellow-tanish colored tub ring that you can see in the video shot at the 45 degree angle. That's a great idea, I'm sorry I didn't think of it before I made the DVD of showing a minute of gentle agitation. It goes from very rough, to probably too gentle. What a pig! I washed five pair of jeans in the machine and after just one load it took off a snap button on the of the jeans. Its really way to rough of a machine, people probably went through a lot of clothes using this machine. |
Post# 45687 , Reply# 15   9/24/2004 at 02:55 (7,147 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 45698 , Reply# 16   9/24/2004 at 09:53 (7,146 days old) by lesto (Atlanta)   |   | |
Mine arrived yesterday. It looks great, Robert! Thank you so much! You can even hear the slight clicking of the timer as it prepares to advance. Looking forward to the next one! Les |
Post# 45703 , Reply# 17   9/24/2004 at 14:43 (7,146 days old) by peteski50 (New York)   |   | |
Hi Robert It just arrived a short time ago. This is real Great. I never realized that the franklin design could realy kick ass like this one does. Realy has exciting clothes movement. But does seem real rough on the clothes. I just finished watching part 1 I will finish the rest of the DVD later Thank you again, Peter |
Post# 45722 , Reply# 18   9/25/2004 at 00:18 (7,146 days old) by kreftgr ()   |   | |
Is there going to be a problem trying to play a DVD made in USA (NTSC) on a DVD player designed for the European (PAL) format? Or how about the TV? Computer? Glen. |
Post# 45862 , Reply# 20   9/27/2004 at 02:27 (7,144 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Glen, I can't play the CD on my computer because it has a CD+R player in it. But the new DVD players can play all formats. PAL vs NTSC is hardly a problem anymore since newer equipment can play both. When I got the first video tapes from the US I had to buy a new VCR however, the one that I already had (a Sharp) was only able to play PAL tapes. I bought a Sony that could play both. Ofcourse taping is another thing, my VCR can't tape in NTSC format. I guess this website is a very expensive one to me LOL. Not only did it make me come to the US a few times, but also makes me buy new equipment now and then. Perhaps I should be treated! |
Post# 45875 , Reply# 21   9/27/2004 at 08:42 (7,143 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 45891 , Reply# 22   9/27/2004 at 12:39 (7,143 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 45931 , Reply# 23   9/27/2004 at 22:23 (7,143 days old) by golittlesport (California)   |   | |
Thanks, Robert. Great video. That machine is indeed a rough, noisy, wasteful pig! But fun to watch. I almost got dizzy seeing that tub spinning around during agitation. Very similar action to a friend's WCI apartment sized washer-dryer. Have you tried to hold the tub still and see how that affects the wash action? And I loved the Westy/Dash commercial. I didn't realize they had two models of the Space Mates. I had always thought the single-knob version was an earlier model. I wonder why they didn't show the different Laundromat models. I did notice the washer/dryer combo in the background. Thanks again for making that! |
Post# 45981 , Reply# 26   9/29/2004 at 02:54 (7,142 days old) by kenmore1978 ()   |   | |
So where are the instrucitons on how to obtain the DVD? |
Post# 45983 , Reply# 27   9/29/2004 at 03:41 (7,142 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 45986 , Reply# 28   9/29/2004 at 04:58 (7,142 days old) by mrb627 (Buford, GA)   |   | |
I got my DVD yesterday. I can't believe that I spent 90 minutes watching a washing machine on my big screen. I especially liked the side view on the second cycle. That's about the angle I would have been viewing this machine back when I was a kid. I also like the coast to a stop spin instead of the harsh braking of more modern machines. Although I think the Frigidaire top loaders of today may still do this. I wondered why it didn't begin filling for the rinse during that coast down minute like the Speed Queens do, but I guess they didn't want to splash any water prematurely over the side of the tub. It could have triggered agitation too early. And what loads of clothes. All that and a throw rug. Not much of a light loader on these vintage machines are you UNI. I noticed that there is a water level or water saver button on the control panel. What does that do? Anyway, thanks for the DVD Unimatic. I eagerly await Volume II. MRB |
Post# 45987 , Reply# 29   9/29/2004 at 05:35 (7,142 days old) by kenmore1978 ()   |   | |
Thanks, I see it now, and saw the button before just didn't register, dummy me |
Post# 46013 , Reply# 31   9/29/2004 at 19:52 (7,141 days old) by mrb627 (Buford, GA)   |   | |
