Thread Number: 12308
hotpoint not spinning out all of the water |
Post# 216456 , Reply# 1   6/16/2007 at 14:43 (6,152 days old) by hotpoint80 ()   |   | |
Sorry all i had to redo this one so ignore the first one.......lol |
Post# 216494 , Reply# 2   6/16/2007 at 18:16 (6,152 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 216505 , Reply# 3   6/16/2007 at 20:34 (6,152 days old) by coldspot66 (Plymouth, Mass)   |   | |
Could be something blocking the drain outlet in the outer tub. GE/Hotpoints pre 1995 machines have a tendency to float small items into the outer tub. Unless the drain hose has been changed, it should be corrugated plastic, which usually doesn't kink. Hope this helps! |
Post# 216525 , Reply# 4   6/16/2007 at 22:52 (6,152 days old) by hotpoint80 ()   |   | |
hey guy's thanks for helping i'll check it out and figure out the problem if nothing hasn't changed i'll ask you guy's again. |
Post# 216572 , Reply# 5   6/17/2007 at 11:06 (6,151 days old) by coldspot66 (Plymouth, Mass)   |   | |
Belt could be streched as well. |
