Thread Number: 12314
Late Model Kenmore TL Not Spinning Correctly |
Post# 216566   6/17/2007 at 10:59 (6,154 days old) by spinmon (st. charles mo )   |   | |
Not much other info.My brother says their later model DD (with spiral tub holes)isn't spinning properly.I'll try to get more info.Says it DOES nuetral drain completely.??? |
Post# 216575 , Reply# 1   6/17/2007 at 11:09 (6,154 days old) by coldspot66 (Plymouth, Mass)   |   | |
Could be a small article of clothing wedged between the tubs or wedged between the tub ring and tub top. If it takes off slowly and takes awhile to climb to full speed, you might have a worn, oily clutch ring that is slipping too much. |
Post# 216873 , Reply# 2   6/19/2007 at 00:34 (6,153 days old) by volvoguy87 (Cincinnati, OH)   |   | |
