Thread Number: 12440
Question about using bleach in a FL |
Post# 217977 , Reply# 1   6/24/2007 at 13:53 (6,150 days old) by frigilux (The Minnesota Prairie)   |   | |
Ultimate Care has some chlorine in it, but it's a weaker solution than regular LCB. Shane, I use standard LCB in 4-5 loads per week (1/3 of a cup, which is the maximum dose my Frigidaire's dispenser will accomodate) and haven't had a problem with either the '96 Electrolux/Frigidaire or my '02. The '96 is still in use, doing laundry for two apartments, although the tenants may not use LCB at all. I've not taken the machine apart to see if there is any damage being done. Several knowledgeable at AW say it is not good for them, especially the FrigiLuxes, which have aluminum spiders. So far I haven't had any catastrophic failures, but I may just be lucky. If you use it only occasionally, I wouldn't worry about it---especially if you're using Ultimate Care. I will certainly let everyone know if I have a spider failure or other bleach-induced problem with my Frigi FL'er. If anyone should have a problem, it should be me, given the amount of LCB that goes through my washer each week. |
Post# 218217 , Reply# 2   6/25/2007 at 17:52 (6,149 days old) by ~sudsshane ()   |   | |
I appreciate the input-- Thanks. |
