Thread Number: 12455
Miele W1215's Premiere Washload |
Post# 218078   6/25/2007 at 00:29 (6,149 days old) by pulsator (Saint Joseph, MI)   |   | |
FINALLY!!! The day has come (and by now gone.) My dad and I got the wiring hooked up to the Miele earlier this afternoon, however I had to go out for thr evening with my dads as a late father's day type thing. But when I got home, I decided to do a nice big colorful load of towels for my Miele's first load ever! I got 6 of my best towels into it and let her go! Here she is all lit up and ready for action!
Post# 218079 , Reply# 1   6/25/2007 at 00:30 (6,149 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 218080 , Reply# 2   6/25/2007 at 00:31 (6,149 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 218081 , Reply# 3   6/25/2007 at 00:31 (6,149 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 218082 , Reply# 4   6/25/2007 at 00:32 (6,149 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 218083 , Reply# 5   6/25/2007 at 00:33 (6,149 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 218084 , Reply# 6   6/25/2007 at 00:34 (6,149 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 218090 , Reply# 7   6/25/2007 at 01:29 (6,149 days old) by ultramatic52 (Mexico City)   |   | |
They are great, and your machine is beautiful!!! Congratulations!!! |
Post# 218091 , Reply# 8   6/25/2007 at 01:34 (6,149 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
A few pointers from another Miele owner? You can use 1 tablespoon or less of Tide HE if you are using STPP. The stuff is very concentrated on it's own and STPP lessens the need for high dosage by half. To really see what a Miele can do, especially with really grungy/badly stained whites, try some Persil or other European/UK front load detergent. All are designed for long washes and even boil washing (temps above 160F) Don't know what kind of water you have, but it probably is no where near as hard as what they've got over on the other side of the pond. Still it does not hurt to run a "descale" wash every few months or so to keep the heating elements/wash tubs free of crud. Hard water deposits are the main cause of heating element failures. Despite what the manual states about cleaning the "lint trap" often, I've never found anything in there worth bothering about. On average one will open the thing up once ever quarter or so and see what is what. Again aside from the odd shirt collar stay, nothing really comes up down there. Then again am very careful about making sure pockets are empty and such before chucking things into the wash. Am sure you have heard this advice already, but try to leave the washer door open between uses. It really does help keep the washer "fresh" inside. For your maiden boil wash, may one humbly suggest the most "stank" items you can find. Your Miele with the proper detergent is more than up for the challenge. Don't know if your washer goes up to 200F like mine, but don't be shocked if you hear bubbling sounds coming from the washer as the temperature rises. That is just the water "boiling"! *LOL* Best of luck with your new baby! L. |
Post# 218095 , Reply# 9   6/25/2007 at 02:03 (6,149 days old) by pulsator (Saint Joseph, MI)   |   | |
The clothes I used for the boil wash weren't stinky really, they were just stained! The load consisted of about 10 washcloths that were grossly dingy, and 2 t-shirts that had bad sweat stains in the pits! Everything came out better than I expected, those stains had been there for over a year and still the Miele managed to get rid of them! The load came out brilliantly white and I can't wait to do more! according to the manual, my Miele will heat to 203 degrees F. However, I thought that machines would usually fill with more cold water near the end of such a high temp wash? I thought Robert's Asko did that when I saw it run, but it was a long time ago and I don't really remember... Kinda worries me to dump near boiling water down the drain, I know it shouldn't really, I do it in the kitchen all the time, but still... I'll keep in mind the Tide usage, although I saw near no sudsing at all in the load I've done so far, and I'm just so used to having suds! |
Post# 218106 , Reply# 11   6/25/2007 at 03:54 (6,149 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
My Miele fills with cold water at the end of the wash cycle (fills to the default rinse level, which is the same as "Delicates") for the cotton cycle. After a bit the water will be drained and the series of rinses will begin. On the Permanent Press cycle, the washer will add cold water as above, but drain down abit, then add more cold water, etc. This goes on several times then until the timer advances over to the first rinse. Purpose of cooling the water in PP cycles, was to prevent wrinkling and creases, especially of man made fibers. However the machine will do this even if the water temperature selected was warm or cold or even tap cold, where there really isn't any need. Cooling water in the cottons cycle is also to prevent creases, especially when using the boiling hot water temperatures of 160F and above. Boilng water won't hurt your plumbing, in fact may help clear out biofilm, grease and muck as the hot water/detergent combination makes their way down. Copper and cast iron pipes can take water temperatures in excess of 200F. Not sure about PVC, but think it must belong the same lines. Back to the Miele. Am surprised that the washer does not add cold water towards the end of uber hot cycles. Not that you want to start messing with your new machine, but peek over on the other Miele thread where a member tells of how he "adjusted" his Miele washer to suit his tastes. Can only assume in yet another attempt to meet US government mandates about water/energy use, certian changes have been made. If you really want to see what a boil wash can do, add 1-2 tablespoons of oxygen bleach such as Ecover. TideHE does not contain oxygen bleach, however Persil does. Nothing smells fresher than whites/lights boil washed in oxygen bleach! L. |
Post# 218108 , Reply# 12   6/25/2007 at 04:22 (6,149 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Hi Jamie, your machine should have many programmable options such as cooling the suds after the main wash, raising the rinse water level, setting the child lock etc. I found out recently that I could program my Miele W1986 to do all these things and more! Check out the manual or if it's not in there (like in my case) call Miele US and ask tech support. Congratulations on your beautiful Miele. Eddy |
Post# 218136 , Reply# 13   6/25/2007 at 09:09 (6,148 days old) by askomiele (Belgium Ghent)   |   | |
Dum question: what's STTP:$ |
Post# 218146 , Reply# 14   6/25/2007 at 10:30 (6,148 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Post# 218159 , Reply# 15   6/25/2007 at 11:43 (6,148 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 218160 , Reply# 16   6/25/2007 at 11:44 (6,148 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 218170 , Reply# 17   6/25/2007 at 12:53 (6,148 days old) by lavamat78800 ()   |   | |
Here is the link of the german version of your machine, Jamie! But i love yours much more. Have fun with it. CLICK HERE TO GO TO lavamat78800's LINK |
Post# 218175 , Reply# 18   6/25/2007 at 13:32 (6,148 days old) by pulsator (Saint Joseph, MI)   |   | |
Well, I've learned so far there a parts that I love about this machine, and parts I hate, but mostly parts I love! I thinkit does an amazing job cleaning and it's so very gentle with everything! I love the noises it makes too! Nothing like a quiet jet plane taking off in the basement! The Good: -BOIL WASH -gentle -quiet -efficient -JET PLANE -flexible -chidlock (requires a passcode to open the door and to get the machine to respnd in any way at all!) -drum light -chrome -stainless The Bad: -only rinses twice (unless the sensitive option is selected, then it will add a rinse, but not raise the water level.) -the rinses are at the same water level as the wash -the softener dispenser does not get cleaned out very well, there ia a lot of fabric softener left over that I have taken to pouring in a few cup of water til it gets cleaned out -it won't fill from just cold water and heat from there, gives an intake error -usually doesn't reach the full 1600 RPM Most of these things I'm sure have been changed to meet US water and energy usage standards and I'm sure I can change them back to European settings somehow... STPP is sodium tripolyphosphate, found in detergents most everywhere except the US. |
Post# 218186 , Reply# 22   6/25/2007 at 15:02 (6,148 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Askomiele, The American machines are somewhat different than the European models. They don't have as much preprogrammable options as the European models, at least preprogrammable by the owner. It might just be that Jamie might have to contact Miele. Have a look at the manuals at the American Miele website. You will see that there aren't as much options as on the European models. I think the lower water levels are a default setting that can't be changed, at least not through normal procedures. I bet there are possibilities to change it, but that will probably have to be done by a Miele technician. Another thing is that these Mieles are connected to hot and cold water, they fill with a somewhat lower temperature than the temperature that is selected IIRC. It's the same system as the Miele Allwater has. |
Post# 218190 , Reply# 23   6/25/2007 at 15:17 (6,148 days old) by askomiele (Belgium Ghent)   |   | |
Oke right forgot about that... this is an american machine your right foraloysius... uhu but with a service call maybe you should get all problems solved maybe even without an intervention... |
Post# 218358 , Reply# 25   6/26/2007 at 05:53 (6,148 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 218388 , Reply# 26   6/26/2007 at 09:11 (6,147 days old) by lavamat78800 ()   |   | |
Jamie, didn´t you have to do a first cycle without any clothes? |
Post# 218956 , Reply# 29   6/27/2007 at 22:50 (6,146 days old) by westtexman (Lubbock, Texas)   |   | |
When you mention your Miele, are you talking about your solid-door model with the automatic timer? Do you also have a W1986, or was I dreaming this? Bryan |
Post# 218957 , Reply# 30   6/27/2007 at 22:51 (6,146 days old) by westtexman (Lubbock, Texas)   |   | |
Mechanical Timer. Must be getting late. |
Post# 218993 , Reply# 31   6/28/2007 at 01:59 (6,146 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 219010 , Reply# 33   6/28/2007 at 05:43 (6,146 days old) by lederstiefel1 ()   |   | |
Here is an exsample for that advertising: Ralf CLICK HERE TO GO TO lederstiefel1's LINK on eBay |
Post# 219027 , Reply# 34   6/28/2007 at 07:42 (6,146 days old) by dnastrau (Lords Valley, PA)   |   | |
As taken from the Internet: STTP — sodium tripolyphosphate — the most commonly used phosphate in detergents beef up a detergent’s cleaning properties by softening hard water and preventing carbonates from settling on the clothes washed. Andrew S. |
Post# 219028 , Reply# 35   6/28/2007 at 07:44 (6,146 days old) by dnastrau (Lords Valley, PA)   |   | |
Sorry for the type-o; I meant STPP |
Post# 219777 , Reply# 36   7/1/2007 at 05:32 (6,143 days old) by irishwashguy (Salem,Oregon.............A Capital City)   |   | |
I have mine on cold water only, however, I was adviced to connect both hoses and use a spilter, it has worked well, although, in the winter time, sometimes it will give me the intake falt just like you decribed. These machines only spin up to 1300 rpm's, and heat atll the way up to 190 F the very hot is 170, hot is 140, very warm is 120 warm is 105, cold is 85, and finally no heat is tap.I asked for the reason that I was accostmed to the novatronic where you set the tem on the big knob, when this series came out, i wanted them instad of the W1986, the tub is better and more gentle on the clothes.One thing that you should know, according to Miele Monty,the tub design contributes and makes up for the spin speed in this way, that it may not be spinning at 1600, the tub makes up for it by helping to extract like it is spinning at 1600. BTW, if you want to see a high water level in this machine, i know that the Wrinkle free sensitve setting can some what accomplish this, that is the way I always set mine as follows, Warm 105-sensative, heavy soil and extended, it just depends on what you are washing, I have even seen it add time for another rinse if the machine feels it has high suds. The Delicate setting has the highest water level of anything, it spins on low, it is fun to watch.This machine is very intuitive.
Post# 220587 , Reply# 37   7/4/2007 at 10:48 (6,139 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
You would turn me onto the newest largest Miele. Over here it states the 4800 and 4840 have a PC update function where a "technician" can update your washer at anytime with his laptop PC! Ofcourse I would need the whole program on my computer and the sacred connector to the machine!! LOL The 4800 has the honeycomb drum------NICE! Yet they are still in a 27 inch cabinet. Are you saying in the NL the 4800 runs only on 110Volts? So the water heater will be slower? Over here the only choice we have for washers is 110V EXCEPT for my 1950's Duomatics which run in 220V and the water heater and dryer run on 220V. I want to take apart a W4800 SOON! Do they have the Service manuals online??? jet |
Post# 220590 , Reply# 38   7/4/2007 at 10:56 (6,139 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
To the best of my knowledge, Miele does not have have service manuals on their USA website. Nor, do they have a parts supply network outside of Miele. If you want/need a part it is ordered from their warehouse, and usually sent directly to the Miele tech who will be coming to your home for the repair. Though many techs have a good supply of parts of their own. Some Miele techs work for Miele, others are independent contractors trained to work on Miele products and have access to parts and such. Miele will send certian parts directly to a customer, such as dispenser drawers, shipping bolts, etc. Do not think they will send things like a motor for DIY work, but could be wrong. L. |
Post# 220657 , Reply# 39   7/4/2007 at 14:53 (6,139 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
