Thread Number: 12656
Another Maytag Saved |
Post# 220927 , Reply# 1   7/5/2007 at 18:37 (6,138 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 221013 , Reply# 3   7/6/2007 at 03:19 (6,137 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Here's a video Liamwa posted a while ago. It shows his Maytag washing.
Post# 221066 , Reply# 4   7/6/2007 at 10:25 (6,137 days old) by rp2813 (Sannazay)   |   | |
Check if it's spinning slow too. I briefly had a 606 that was slow to get up to speed on agitation and never got up to full spin speed. I didn't bother trying to diagnose the problem. I had purchased the machine used from a dealer and was annoyed that the guy didn't even check it for proper operation so returned it and got my money back. Too bad, as that machine would probably still be my daily driver if it had functioned properly.
Post# 221079 , Reply# 5   7/6/2007 at 12:05 (6,137 days old) by irishwashguy (Salem,Oregon.............A Capital City)   |   | |
On a Maytag, the belts are to be a little loose actually. It could be ok to check them to see if they have any wear issues. With that said, they should be replaced about every ten years if the machine is in regular use. They are very easy to replace if need be. Tilt the machine backward, there are two belts, the drive belt from the motor, and the pump belt, called a poly pump, they should have alot of play in them.......they slip off and replace very easy.
