Thread Number: 12681
Is my dishwasher loaded correctly? |
Post# 221232 , Reply# 1   7/7/2007 at 15:30 (6,135 days old) by exploder3211 ()   |   | |
Heres the top rack |
Post# 221236 , Reply# 2   7/7/2007 at 16:01 (6,135 days old) by johnb300m (Chicago)   |   | |
Post# 221237 , Reply# 3   7/7/2007 at 16:06 (6,135 days old) by glamwales ()   |   | |
Im not sure on american dishwashers , but i would expect the long frying pan spat and spoon to obstruct the upper rack wash arm. come to mention it , is there a upper wash arm ? |
Post# 221239 , Reply# 4   7/7/2007 at 16:18 (6,135 days old) by exploder3211 ()   |   | |
No upper arm.. LoL, i added a blue cup and a gree butter container that some how did not get pictured |
Post# 221269 , Reply# 6   7/7/2007 at 20:22 (6,134 days old) by appnut (TX)   |   | |
Ya did fine loading. Did stuff not come clean? Other than the loading question, what's the issue here? No, this is a BOL Hotpoint. It has no 3rd level constant rinse. Just the poop up tower in the middle of the bottom rack. Hot Start is 'recent" "invention" on these machines. I've seen the cycle sequence that it adds about 3 gallons more water and about 20 or so minutes to the cycle, but I don't know what actually happens in that added 20 to 30 minutes vs. just heavy soil. Personally, id idn't have good luck with Wally World branded dtergent, the box I tried. So I've never bought another one. And personally I odn't like tabs cuz ya can't vary the dosage. |
Post# 221289 , Reply# 7   7/7/2007 at 21:15 (6,134 days old) by exploder3211 ()   |   | |
Nothing comes clean at all. Took the trap apart and spray arm off and cleaned both.. Dishwasher is make a much diffrent woosh woosh (deeper and not as loud) |
Post# 221319 , Reply# 8   7/8/2007 at 03:34 (6,134 days old) by spankomatic (Ukiah,CA)   |   | |
I had a Hot Point years ago in a rental. Same style with the tower. Had the same problem. Land lords sent the repair people out twice. They never were able to get the machine to work properly. I moved. Now I have Magic Chef in the unit I'm in now. I have had GE and Magic Chef dishwashers with the same design. All are bad machines. I find that if you only load dishes on the bottom rack the lower spray arm will get the upper rack somewhat clean. Large bowls and pans on the bottom rack block the spray to the top rack. I don't think even your bottom spray arm is turning like it should and very doubtfull that the "tower" is erecting like it should. The filtration system in these machines only filers large objects like a steak. Recomendation: Don't spend anymore time on it or money. Spend your time looking for a new dishwasher (Kitchenaid) and your money on a machine the washes dishes like it is supose to. I like Kitchenaid. I like the loading features. You don't have to load around the "tower" on the lower rack. They have a good filtration system so you don't have to pre rinse the dishes. Scrape and load. That easy! They come out CLEAN. You do not need top of the line Kitchenaid to get clean dishes. I would pick a model with Sani Cycle. I have also had Kenmore portable dishwasher which is very similar to the Kitchenaid that I was very happy with also. Photo's are of the Kenmore I had. Good machine. Keep us posted..... Jim |
Post# 221320 , Reply# 9   7/8/2007 at 03:36 (6,134 days old) by spankomatic (Ukiah,CA)   |   | |
Post# 221321 , Reply# 10   7/8/2007 at 03:38 (6,134 days old) by spankomatic (Ukiah,CA)   |   | |
Post# 221331 , Reply# 11   7/8/2007 at 08:09 (6,134 days old) by spankomatic (Ukiah,CA)   |   | |
Post# 221347 , Reply# 13   7/8/2007 at 09:16 (6,134 days old) by exploder3211 ()   |   | |
LoL Can't change it out cause its an apartment Have a couple diffrent idead am going tp play with |
Post# 221526 , Reply# 14   7/9/2007 at 00:51 (6,133 days old) by spankomatic (Ukiah,CA)   |   | |
Post# 221539 , Reply# 15   7/9/2007 at 04:06 (6,133 days old) by panthera (Rocky Mountains)   |   | |
Basically - except for the glass in the front right hand corner, I think it is fine. These machines can and do clean ok, you just have to give them a fighting chance. When I have to use one in the US, I do the following and it works well (all the purists please stop reading here). 1) A pre-rinse is a must. 2) Use the hottest water you can get, even if that means running the tap before hand. Wasteful, unless the water has a use. 3) Use enzymes (Wally Mart, even if I don't like them has a very high enzyme detergent) but NOT with any other detergent. The chlorine bleach in the other detergents kills the enzymes! 4) Add one tablespoon of baking soda to the detergent cup. If it makes a difference, then your water is too hard to wash well without help. There are cheaper water softeners, but since you eat and drink from these things, I'd stay away from them. Work down from the tablespoon until you find what works. 5) The "tower of power" is not that bad, it just doesn't do corners. 6) If the wash cycle is unheated, I have found it helps enormously to reset the timer so it washes twice with the same water. Dishwasher detergents are not like washing machine detergents, they don't lose all their effectiveness after 15 minutes. Good luck and let us know..oh, and you may be pre-rinsing too well in the sink before hand. There has to be some grease or oil on the plates for the detergents to build "soap" to clean with. By the way, when is your husband finally going to help around the house? If women want men like that fine, but ladies like us don't have to put up with it. You can't keep those nails pretty and your "do" wavy if you spend all your time on your knees. Er, let's rephrase that before Toggles reads this... |
Post# 221583 , Reply# 17   7/9/2007 at 11:02 (6,133 days old) by panthera (Rocky Mountains)   |   | |
Chad, dahling, they do say foxglove makes the most lovely salad topping...and, unless they are testing directly for it, it looks like his heart...just...gave...out. Before the politically correct crowd freak, just kidding. Do not try this at home, children. That man will live because he got prompt medical attention. I shudder to think what goes (on) in the washing machine when you aren't home. |
Post# 221631 , Reply# 18   7/9/2007 at 17:22 (6,133 days old) by exploder3211 ()   |   | |
Nothing.. He doesnt do laundry and can't figure out the new washer.. Hasn't touched the new washer at all, and he won't touch the dishwasher again.. He won't tell me what he bathed in there either... |
Post# 223811 , Reply# 19   7/19/2007 at 18:38 (6,123 days old) by toggleswitch (New York City, NY)   |   | |
Post# 223892 , Reply# 20   7/19/2007 at 22:42 (6,122 days old) by exploder3211 ()   |   | |
Who knows waht he washed// But it won't happen again |
Post# 223926 , Reply# 21   7/20/2007 at 06:02 (6,122 days old) by toggleswitch (New York City, NY)   |   | |
Post# 224107 , Reply# 22   7/20/2007 at 23:03 (6,121 days old) by exploder3211 ()   |   | |
Pot Storage.. Do you mean this kinda pot? CLICK HERE TO GO TO exploder3211's LINK |
Post# 224158 , Reply# 23   7/21/2007 at 06:39 (6,121 days old) by toggleswitch (New York City, NY)   |   | |
Post# 224223 , Reply# 24   7/21/2007 at 12:46 (6,121 days old) by exploder3211 ()   |   | |
K makin sure |
Post# 224306 , Reply# 25   7/21/2007 at 17:28 (6,121 days old) by mrcleanjeans (milwaukee wi)   |   | |
there's NO WAY that the so called Power Tower will reach under all parts of the top rack.The large items up there tilted toward it should get hit but not the glasses to the right, especially the wrongly tilted glass.I am not a tower fan. |
