Thread Number: 12713
Calypso!!!!!!!!! questions and pics |
Post# 221664 , Reply# 1   7/9/2007 at 20:49 (6,133 days old) by jaxsunst ()   |   | |
Where is the model number on it? Or, what is the model number? |
Post# 221665 , Reply# 2   7/9/2007 at 21:11 (6,133 days old) by jaxsunst ()   |   | |
Action Shot |
Post# 221666 , Reply# 3   7/9/2007 at 21:14 (6,133 days old) by jaxsunst ()   |   | |
He is still loved and has a home. |
Post# 221667 , Reply# 4   7/9/2007 at 21:16 (6,133 days old) by jaxsunst ()   |   | |
Here is the dryer. The guy told me that if he found a dryer matching the Calypso, he would call me. He is also watching out for GM Frigidaires :-) |
Post# 221675 , Reply# 7   7/9/2007 at 21:38 (6,133 days old) by dadoes (TX, U.S. of A.)   |   | |
Yours is a Kenmore. Mine is a Whirly. On mine, there's a medallion insert at the front of the top panel. Pry it out carefully, remove a screw. Use a putty knife (or just pull forward) to release the top from the hold-down clips. There are then four screws to remove the front panel. You don't have a medallion ... so it may just be a matter of locating and releasing the two hold-down clips. Once you raise the top, and pull the front panel, and pull the bottom panel, you may find some rust. Pictures, please!! There may also be a tech info sheet inside the front panel. The lid switch can't be manually tricked very easily. It's hidden under the top panel, triggered by the lid hinge. Also, the machine won't start a new cycle until the lid is opened and closed, which is sensed via the lid switch. What I did is remove the rear cover on the control panel, remove the harness plug for the lid switch and place a jumper wire in the plug. Either remove and replace the jumper to "break" the lid switch circuit for running the next cycle .... or unplug the machine for 20 seconds or so to kill the power and reset the circuit boards. AndrewInOrlando replaced his leveler and u-joint recently, I'm sure he'll come along and give you some pointers. :-) You can find a service manual, Whirly-style, at http://www.servicematters.com, Technical Reference section, Technical Library, Job Aids, Laundry Products, 2nd page, document L-67 |
Post# 221676 , Reply# 8   7/9/2007 at 21:39 (6,133 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 221678 , Reply# 10   7/9/2007 at 21:41 (6,133 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 221682 , Reply# 12   7/9/2007 at 21:48 (6,133 days old) by dadoes (TX, U.S. of A.)   |   | |
A more permanent way around the lid switch is to locate the two wires running to it from inside the control panel. Cut and splice them together to bypass the switch ... but also include a pushbutton momentary-contact (normally closed) or toggle switch for resetting the circuit so the controller board thinks the lid has been opened. You can drill a hole in the side panel of the console and mount the switch there. I haven't done that, being as it's just as easy to remove/replace the jumper wire or pull the power plug.
Post# 221694 , Reply# 16   7/9/2007 at 22:22 (6,133 days old) by alr2903 (TN)   |   | |
Jackson glad you went out and bought it. $20.00 phewww, most wasted more than that on lotto tickets 07-07-07 |
Post# 221707 , Reply# 18   7/9/2007 at 22:56 (6,133 days old) by andrewinorlando ()   |   | |
Jax - check your e-mail. |
Post# 221791 , Reply# 19   7/10/2007 at 11:50 (6,133 days old) by jaxsunst ()   |   | |
Got it, Thanks. |
Post# 221795 , Reply# 20   7/10/2007 at 12:34 (6,133 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 221865 , Reply# 22   7/10/2007 at 21:13 (6,132 days old) by andrewinorlando ()   |   | |
Could be a broken mounting strut or strut mount. Easy fix if it's a front one, a little harder if it's a rear one. |
Post# 222360 , Reply# 26   7/13/2007 at 11:18 (6,130 days old) by jaxsunst ()   |   | |
Forgot to mention. Looking from the top, I think I have identified the offending strut. The one on the front left appears to stick out further than the others. Just an observation. |
Post# 222408 , Reply# 29   7/13/2007 at 15:53 (6,130 days old) by dadoes (TX, U.S. of A.)   |   | |
Jackson, are the front panel screws on your Kenmore perhaps Torx or square-drive?? My Whirly has four Philips screws as Andrew describes. I'm thinking the tool you ordered from RepairClinic is for the basket spanner nut, not the front panel. Another place to look for parts is Sears Parts Online. They have diagrams for most brands/models. CLICK HERE TO GO TO dadoes's LINK |
Post# 222698 , Reply# 31   7/14/2007 at 22:04 (6,128 days old) by laundryshark (Cedar Rapids, Iowa)   |   | |
My cravings for Calypso videos would increase all the more. Any wonder I am having fun killing bordom this fine Saturday evening? Many thanks.--Laundry Shark |
Post# 222780 , Reply# 32   7/15/2007 at 10:08 (6,128 days old) by toggleswitch (New York City, NY)   |   | |
*WOW* (Faint) Storage-type hot water heater=> Plug and [flex] cord connected? These don't require a neutral (as there are no 110v components) so at least the ground [earth] and neutral don't have to share a conductor, even if this dryer plug has only three prongs/conductors. We now return to our regularly scheduled program........... |
Post# 222932 , Reply# 34   7/15/2007 at 22:18 (6,127 days old) by andrewinorlando ()   |   | |
Jax - How does it clean compared to the old Kenmore DD? Any idea yet? |
Post# 222941 , Reply# 35   7/15/2007 at 23:38 (6,127 days old) by jaxsunst ()   |   | |
On my shop towels it did a better job. They came out looking new, no oil stains at all. i will be doing my first real wash day with it tomorrow, I'll let you know. |
Post# 223011 , Reply# 36   7/16/2007 at 07:00 (6,127 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 223108 , Reply# 39   7/16/2007 at 17:24 (6,127 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 223142 , Reply# 41   7/16/2007 at 19:59 (6,126 days old) by appnut (TX)   |   | |
Jackson congratulations. Magic Clean loved his Calypso when he had it. They really aren't bad machines. If you sort properly and don't overload, it does wonders according to Leslie. It's just not a mahcine intended for you to throw all sorts of things into a load at the same time that should be dealt with differently. I know you'll enjoy it. It's a fun machine. Enjoyed using Glenn's.
Post# 223175 , Reply# 42   7/16/2007 at 21:55 (6,126 days old) by jaxsunst ()   |   | |
Repair clinic agrees with everyone else that it needs a u-joint. I just ordered the u-joint kit which includes an inner wash plate and leveler. I also ordered the spanner wrench. Got both for $130 with shipping. |
Post# 223263 , Reply# 44   7/17/2007 at 08:35 (6,126 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 223334 , Reply# 45   7/17/2007 at 13:53 (6,126 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 223341 , Reply# 47   7/17/2007 at 14:28 (6,126 days old) by andrewinorlando ()   |   | |
Jax - Did you get it open and take a look at its suspension yet? |
Post# 223349 , Reply# 48   7/17/2007 at 14:52 (6,126 days old) by jaxsunst ()   |   | |
the tool should arrive today or tomorrow. |
Post# 223423 , Reply# 49   7/17/2007 at 20:27 (6,125 days old) by appnut (TX)   |   | |
Post# 223613 , Reply# 51   7/18/2007 at 20:50 (6,124 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 223654 , Reply# 53   7/18/2007 at 22:17 (6,124 days old) by appnut (TX)   |   | |
Post# 223680 , Reply# 54   7/19/2007 at 01:14 (6,124 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 223731 , Reply# 55   7/19/2007 at 08:51 (6,124 days old) by jaxsunst ()   |   | |
I saw that on yours on the video. Mine jerks around 90 degrees and jumps when stopping. I will try to post the vid tonight, if it drops below 90 degrees up there. |
Post# 223833 , Reply# 59   7/19/2007 at 19:42 (6,123 days old) by jaxsunst ()   |   | |
the u-joint kit and spanner wrench came in today. Will work on it Saturday. A/C just showed up and it working (again) on the upstairs unit. It is 91 up there. Spin Brake, is it in the book you sent? I'll look it up. |
Post# 223851 , Reply# 60   7/19/2007 at 20:35 (6,123 days old) by jaxsunst ()   |   | |
Tell me more about the spin brake. While I was watching it, I noticed that it has new black newer style pump. |
Post# 224364 , Reply# 62   7/21/2007 at 21:51 (6,121 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 224372 , Reply# 63   7/21/2007 at 22:36 (6,121 days old) by andrewinorlando ()   |   | |
Yep, that's a two piece pump.....bottom piece snaps off the motor with those two clips at the side. |
Post# 224604 , Reply# 64   7/22/2007 at 22:02 (6,120 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 224636 , Reply# 65   7/23/2007 at 05:45 (6,120 days old) by jaxsunst ()   |   | |
that's what I have. |
