Thread Number: 12857
Fridgemore Dryer D.O.A. |
Post# 223660 , Reply# 1   7/18/2007 at 22:53 (6,119 days old) by liamwa ()   |   | |
My sister has the same set. The dryer broke down after she had it only one month. The control board needed to be replaced I believe. Its now been three years with no more problems. Liam |
Post# 223769 , Reply# 4   7/19/2007 at 14:51 (6,118 days old) by nurdlinger (Tucson AZ)   |   | |
Post# 223782 , Reply# 5   7/19/2007 at 16:17 (6,118 days old) by coldspot66 (Plymouth, Mass)   |   | |
There is a thermal fuse attached to the interior rear of the cabinet. It has 2 wires attached to it and is in series with the motor circuit. If the cabinet gets too hot because of poor venting or a failed thermostat it will open and not allow the motor to start. |
Post# 224098 , Reply# 7   7/20/2007 at 22:20 (6,117 days old) by nurdlinger (Tucson AZ)   |   | |
There are not as many manuals for this model as for Kenmores and Frigidaires. The link will get you a PDF of the circuit diagram. The other manuals are pretty generic, there is a two-page document describing the operating instructions at 131920900.pdf
CLICK HERE TO GO TO nurdlinger's LINK |
Post# 224099 , Reply# 8   7/20/2007 at 22:24 (6,117 days old) by nurdlinger (Tucson AZ)   |   | |
Post# 224190 , Reply# 9   7/21/2007 at 10:12 (6,116 days old) by washernut ()   |   | |
I replaced the thermal fuse this morning and she took right off again. Thanks so much for your help guys. You saved me a service call. Bill |
