Thread Number: 12898
Calypso, Repair in Progress
Post# 224188   7/21/2007 at 09:54 (6,114 days old) by jaxsunst ()
Oh course my camera battery died, it is recharging now. I have it taken apart down to the spanner nut. I have been hammering on it for about 30 minutes.
Is the u-joint supposed to move with the nut? It is.
Am I just not being patent enough and need to keep hammering?
Post# 224192 , Reply# 1   7/21/2007 at 10:20 (6,114 days old) by jaxsunst ()
Here is a pic, the entire thing moves.
Post# 224308 , Reply# 2   7/21/2007 at 17:39 (6,113 days old) by andrewinorlando ()
That u-joint looks like it's fine. The boot isn't torn or damaged.
Post# 224396 , Reply# 3   7/22/2007 at 01:48 (6,113 days old) by dadoes (TX, U.S. of A.)
dadoes's profile picture
Maybe the u-joint is OK and the knocking noise during high-speed spin is from the broken shock you mentioned previously? Have you gotten the front panel off for a look? I believe you can also see the shocks from beneath. Try to get out as much water as possible. Or take off the back panel and remove the lower hose from the sump, with a pan ready to catch the water out of the sump. Lay the machine on its back, prop it up with something if possible to keep the sump end lower to help prevent any residual water from running out from the tub ring openings or wherever. Remove the bottom panel and have a look.
Post# 224531 , Reply# 4   7/22/2007 at 15:59 (6,112 days old) by jaxsunst ()
pics of what's going on
I found when I had it on it's back that one of the struts was leaking oil. Also, the shocks on the front bottom are very greasy with a lot of loose grease.
Post# 224532 , Reply# 5   7/22/2007 at 16:00 (6,112 days old) by jaxsunst ()
another
Look at my feet!!!!
Also notice the orange vintage floor in my garage.
Post# 224533 , Reply# 6   7/22/2007 at 16:01 (6,112 days old) by jaxsunst ()
And another
Post# 224534 , Reply# 7   7/22/2007 at 16:02 (6,112 days old) by jaxsunst ()
bottom plate
Look, no rust
Post# 224536 , Reply# 8   7/22/2007 at 16:10 (6,112 days old) by vintagesearch ()
wo its pretty much intact no rust grime or anything still looks new wow!
Post# 224539 , Reply# 9   7/22/2007 at 16:25 (6,112 days old) by jaxsunst ()
I forgot to ask, does the balance ring supposed to have water in it?
Post# 224540 , Reply# 10   7/22/2007 at 16:26 (6,112 days old) by jaxsunst ()
on the next to the last pic, if you look under the strut on the left, you can see the small puddle of oil
Post# 224591 , Reply# 11   7/22/2007 at 21:37 (6,112 days old) by andrewinorlando ()
Jackson-
That machine is in perfect condition. It looks brand new inside.
The balance ring is filled with water, seawater, I believe. It's why these machines have such amazing ability to complete cycles with the most out of balance loads...even washing a single pillow is no problem for it. In six years, I've never had mine shut down because of an out of balance condition...it always completes the cycle.
It's very hard to say whether or not the struts are the issue. Mine do not leak oil, I know that from working on it. You may have a bad one. But with the panels off the machine, if you re-assemble the tub and top, you can start the machine up and see how it reacts during spin and see if you can hear where the noise is coming from while watching for excessive tub movement. It should spin pretty steadily, just some minor rocking, but definitely no twisting of the tub. You'll get some "tub twist" when the machine shuts down after the final high speed spin with a load in it...that's normal.
When you re-assemble the top, make sure all the rubber flanges are correctly in place under the top lid of the machine. Their placement is obvious, but if they are outta place, the machine will splash water over the tub while it's washing, causing unsightly rust underneath.
I hope you can return the u-joint and leveler???
Another thing I would do
Post# 224612 , Reply# 12   7/22/2007 at 22:40 (6,112 days old) by dadoes (TX, U.S. of A.)
Are the tub struts hydraulic/oil-filled? I haven't examined them closely and don't recall from the tech manual, but I figured they were simply spring supports.
Your Calypso is pristine compared to mine!
Post# 224638 , Reply# 13   7/23/2007 at 06:42 (6,112 days old) by jaxsunst ()
video
I just posted a video of the problem. The lighting is not great. If there are any angles or changes anyone would like to make, please let me know.
CLICK HERE TO GO TO jaxsunst's LINK
Post# 224649 , Reply# 14   7/23/2007 at 09:16 (6,112 days old) by bundtboy ()
inner and outter tubs rubbing
Your tubs are rubbing. I don't know how to explain why, but they are. Is the main wash tub loose on it's hub?
B
Post# 224667 , Reply# 15   7/23/2007 at 10:40 (6,112 days old) by bundtboy ()
bent
...could the tub be actually bent at the hub? Just a guess - but I can see in the video that the inner tub is not concentric to the lid opening. It looks like it's in crooked - or possibly bent.
B
Post# 224668 , Reply# 16   7/23/2007 at 10:41 (6,112 days old) by jaxsunst ()
I found where it is rubbing, it is the balance ring rubbing against the outer ring. I must have done something wrong reassembling them.
Post# 224708 , Reply# 17   7/23/2007 at 15:02 (6,112 days old) by dadoes (TX, U.S. of A.)
You haven't yet removed the inner basket or changed the u-joint, correct? Is there fluid in the balance ring?
Mine has never had an OOB situation (perhaps I should force one to see what happens?). Seems odd it gets up to high speed before triggering an OOB, shouldn't that happen much sooner (if the load is really OOB)? There's no OOB switch in terms of sensing tub oscillations, if I understand correctly it works via motor current. Something is apparently putting the motor under more of a load that normal.
Post# 224712 , Reply# 18   7/23/2007 at 16:09 (6,111 days old) by jaxsunst ()
Yes, the balance ring has some kind of fluid in it. Judging by holding it, it is about half full.
No, the u-joint looked new, so I put the new grommets, seals, leveler, and inner wash dome in.
Post# 224728 , Reply# 19   7/23/2007 at 17:56 (6,111 days old) by andrewinorlando ()
The balance ring should be about half full with liquid. The way the machine stops when it's at full spin is fairly normal....minor twisting of the tub. You definitely haven't got it put together correctly. Something is rubbing against something somewhere.
The last 40 seconds of the video where it's at high speed spin definitely seems like there is too much movement of the tub assemblies. Mine is much more sturdy than that and that may be triggering the OB error. Like I said before, I've never been able to get mine to go out of balance, no matter what I put in it. It always completes the cycle. If the machine is not assembled correctly, its going to be hard to diagnose the problem, though, so another video without the rubbing noise would really help. I'm not hearing the other noise you spoke about when it reaches high speed.
Andrew
Post# 224943 , Reply# 20   7/24/2007 at 13:28 (6,111 days old) by jaxsunst ()
When I described the symptoms to RepairClinic.com, they said that it could be either the u-joint or drive motor. Could the motor be my problem?
I didn't get to work on it last night. I was on the phone with AHS most of the evening. It is amazing how quickly things can start happening when you drop a few f-bombs.
Post# 224968 , Reply# 21   7/24/2007 at 17:01 (6,110 days old) by dadoes (TX, U.S. of A.)
Pondering on this a little ... unless I'm missing something, I don't see how either the u-joint or leveler could cause excess vibration/oscillation of the tub during spin. When spinning, it all locks together and rotates as a unit. Wouldn't u-joint trouble especially manifest during nutation?
Post# 224974 , Reply# 22   7/24/2007 at 17:34 (6,110 days old) by andrewinorlando ()
It's definitely not the u-joint or leveler, unless they're not leveling the wash plate out before it goes into spin.
How could the motor be the culprit? The spin shaft could be bent or damaged, possibly even from trying to remove the u-joint. It doesn't make sense that the spanning nut couldn't be loosened, but perhaps in the process of trying to remove it, damage to other components occurred? A bent spin shaft could cause the problem you see in the video.
I still don't recall seeing any oil near or around the strut supports on my machine....maybe still a problem there. I'm at a loss otherwise. Might need a complete teardown to get to the bottom of it? Just fyi...the washbasket is cone shaped at the bottom, but still symetrical...make sure the basket is not out of round, too. If the balance ring were leaking, you would be able to see it.
Post# 225015 , Reply# 23   7/24/2007 at 20:55 (6,110 days old) by jaxsunst ()
The balance ring has a leak. I took it back out, and was moving it around, and it literally sprayed liquid out of a hole.
Post# 225021 , Reply# 24   7/24/2007 at 21:22 (6,110 days old) by jaxsunst ()
When I removed it the first time, I noticed that it was wet, and thought that it just must be some residual water. Sitting on it's side in my garage, it has made quite the puddle.
Found one on Ebay for $15
Post# 225059 , Reply# 25   7/24/2007 at 22:46 (6,110 days old) by dadoes (TX, U.S. of A.)
Yay!
Post# 225134 , Reply# 26   7/25/2007 at 10:27 (6,110 days old) by andrewinorlando ()
There ya go!! Good find Jackson! Probably had a small leak all along.......
Post# 225572 , Reply# 27   7/27/2007 at 06:25 (6,108 days old) by jaxsunst ()
New ring should be here middle of next week. I will do laundry in the DD this week and polish and make the Calypso all pretty.
Post# 226884 , Reply# 28   8/1/2007 at 22:12 (6,102 days old) by dadoes (TX, U.S. of A.)
Status? :-)
There's a Calypso pair listed at a local garage sale on Fri. Investigation reveals the seller is someone who I kinda know in passing. Hmmmm.
Post# 226888 , Reply# 29   8/1/2007 at 22:23 (6,102 days old) by bpetersxx (laf in on the banks of the Wabash River)
bpetersxx's profile picture
Go get them Glenn
Having two is twice is nice and a dryer is better
Now if I can figure out to not oversudsyfoam mine
Post# 226935 , Reply# 30   8/2/2007 at 06:02 (6,102 days old) by jaxsunst ()
Got shipping confirmation on the Balance Ring Tuesday. It should be here Friday or Saturday. It is being shipped priority mail from Colorado. Of course, I'm out of town for family obligations this weekend. I plan to have it working and doing this weeks laundry on Monday.
Glenn, are they Whirlpool or Kenmore, what color, how much. I would like to have the matching dryer.
I agree, go get them.
Post# 227058 , Reply# 31   8/2/2007 at 15:06 (6,102 days old) by dadoes (TX, U.S. of A.)
I don't yet have any details. The ad description only says "Calypso washer & dryer." The garage sale is listed for Friday only. I called, left a message & number, advised that I work very late into the night and can't get to the sale early for a fair chance at the pair. Remains to be seen if anyone calls back.
Post# 227089 , Reply# 32   8/2/2007 at 16:02 (6,101 days old) by pulsator (Saint Joseph, MI)
pulsator's profile picture
Glenn, hey if you end up gettin 2 Calypsos and wanna get rid of one, let me know, perhpas I'll buy one off ya!
Post# 227176 , Reply# 33   8/2/2007 at 21:33 (6,101 days old) by jaxsunst ()
Balance ring arrived today. Pics of maiden wash will be posted soon.
Post# 227189 , Reply# 34   8/2/2007 at 22:09 (6,101 days old) by andrewinorlando ()
Hopefully it solved the knocking problem?? Got my fingers crossed for you.
Post# 227331 , Reply# 35   8/3/2007 at 12:47 (6,101 days old) by jaxsunst ()
No dice,
It did the same thing. Gives OB error after trying to switch to high speed spin. I noticed a lot of shavings in the tub. It looks like there is something causing the balance ring to sit too high, or the outer ring to sit too low. The tub does not move up and down. So I need to think about it.
Post# 227343 , Reply# 36   8/3/2007 at 14:46 (6,101 days old) by andrewinorlando ()
Jackson -
This may be what caused the leak in the balance ring in the first place...something hitting into it.
The entire tub assmebly, if you grab it from the outside, should be able to be pushed up and down on those struts that sit underneath the machine. It also moves from side to side on the 4 shocks that are mounted to the exterior of the tub. That seems to be fine on your machine. If it won't move up and down, something's not right. Now it does not move up and down easily, but it does move. Those struts maintain the tub height against the rubber seal that runs around the interior of the tub, under the lid. I think it's beige in color, and you can see it when you open the lid on the machine. Those stuts keep the tub from dropping to low under load, and allowing water to splash out over the side, as well as just keep the "ride height", if you will, stable.
You may still be looking at a complete disassembly to get to the bottom of it. I'm at a loss, except to think that maybe the spin shaft is somehow bent?
You have checked all 4 of the shocks that are attached at the exterior of the tub around the machine? I'm sorry that I can't give you a more definitive direction to look in, but I'm stumped. I'm gonna check my Calypso manual tomorrow tonite and see if maybe I've missed something. That machine is too pristine to give up on!!!
Andrew
Post# 227344 , Reply# 37   8/3/2007 at 15:03 (6,101 days old) by spirit ()
Jaxsunst,
I think bundtboy could be right about the tub. When you put the link up, the part when the washer started to spin it sounds like it is grinding & started to shake before the OB. I play the video again and it looks like the top of the internal tub is bent and/or the tub itself is not in right and could cause the OB.
Just a thought though.
Post# 227380 , Reply# 38   8/3/2007 at 19:00 (6,100 days old) by andrewinorlando ()
Could be right...tub could be out of round. Or the shaft it rotates on could be bent. Might explain why the machine shows so little use? Maybe never worked right at all for the previous owners.
Post# 227522 , Reply# 39   8/4/2007 at 08:42 (6,100 days old) by bpetersxx (laf in on the banks of the Wabash River)
the club members are right
I think u are going to have to take out the inner tub and check it and the shafts for damage
maybe the other members can chime in on this :
can u test the machine with the inner tub out to see if the drive shaft is bent
Post# 228006 , Reply# 40   8/6/2007 at 04:28 (6,098 days old) by bpetersxx (laf in on the banks of the Wabash River)
Thread# 12283 More Calypso Pictures
Originally Posted: 6/14/2007-20:49 by bpetersxx
Number of Replies: 18 -- Last Reply by bpetersxx, at 8/6/2007-04:24
A little something for the club
Post# 228017 , Reply# 41   8/6/2007 at 06:57 (6,098 days old) by jaxsunst ()
Could that have something to do with the fact that I couldn't get the spanner nut out because the shaft it is connected to turned with it when I tried to use a mallet?
Post# 228129 , Reply# 42   8/6/2007 at 17:39 (6,097 days old) by andrewinorlando ()
It could very well be...it's hard to tell without seeing the machine. You should have been able to get that spanning nut loose with just a little effort. I was concerned that the whole thing seems to be stuck together. It's not a difficult disassembly, but getting that nut loose is required to get the tub or that shaft out. It may be very slightly out of round (the tub) which may explain why it wobbles only at the high speed spin.
Post# 228133 , Reply# 43   8/6/2007 at 18:06 (6,097 days old) by dadoes (TX, U.S. of A.)
It might be kinda normal for the basket to have an impetus to turn (depending on strength of the brake) when the spanner nut is whacked. Could somebody hold the basket still? If the nut won't come off, might have to carefully chisel it.
Post# 228349 , Reply# 44   8/7/2007 at 16:46 (6,096 days old) by ktm137 ()
Sorry to butt in here, but I have the same issue with my Calypso, and may at least be able to chime in with some info.
First, getting the lock nut off gave me some fits using the universal too bought at the helpful local appliance repair place. The prongs on the took are too 'tall' and tried to move the whole shaft instead of just the nut. Holding it up just a bit while whacking it solved the issue. Also, the nut is a normal threaded one - the tech at the shop thought it was reverse threaded.
Ok, even before I got the nut and then the u-joint off, I noticed that the inner basket turned and moved up and down, wobbled, etc. independant of the hub/inner wash plate.
Once I got the basket out, it is pretty clear that the hub shold be tight on the basket. At least I _think_ that's the case - can someone with a working Calypso confirm that they can't move the basket w/out turning the rest of the assembly?
I don't see a great way to tighten the hub that sandwiches the basket between it. Any thoughts?
I hope this helps a bit - this is the closest to my OB issues on my system, and before I plunk $150+ for a new basket, plus a balancing ring that got worn through, and a new outer wash plate since the gasket is deformed (total of about $250 in parts) I wanted to see if I was alone with this issue :-)
Thanks much,
Kevin M.
Post# 228394 , Reply# 45   8/7/2007 at 20:44 (6,096 days old) by jaxsunst ()
I may try lifting the nut, thanks.
Right now, the Calypso is going to have to be shelved until my garage drops below 90 degrees. That will give me an opportunity to do some real research. i will probably get back into it in a couple of weeks.
Post# 228775 , Reply# 46   8/8/2007 at 20:19 (6,095 days old) by funguy10 ()
That's why you should never have bought a Kenmore Crapypso in the first place and just stuck with the durable DD Kenmore.
Post# 231212 , Reply# 47   8/17/2007 at 19:04 (6,086 days old) by dadoes (TX, U.S. of A.)
If the mechanism has been disassembled previously, I'm wondering if the components and/or basket aren't properly aligned ... which may also explain your difficulty in getting the spanner nut loose.
Post# 231271 , Reply# 48   8/18/2007 at 00:22 (6,086 days old) by andrewinorlando ()
Glenn is absolutely right...if the machine was previously disassembled/re-assembled incorrectly, this would cause the problem you're having with it now. When I disassembled mine, hitting the nut did not cause anything else to turn along with it. Everything stayed put, and just the nut turned, though it was hard to loosen. Once it begain turning though, it came right off with no problem. I know when the machine if off, you can't turn the tub at all, it won't budge. But no problems at all since I fixed her.
Question: If you open the machine while it's spinning, does it brake and stop immediately?
Post# 231272 , Reply# 49   8/18/2007 at 00:35 (6,086 days old) by andrewinorlando ()
Jackson -
I watched your video a couple of times again, and I don't think the problem is in the suspension at all. That looks like it's working as it should. All the shaking and vibration is in the basket, so the problem seems to be with either the shaft or the basket, or, it's very possible that something is caught underneath the basket itself. The suspension is absorbing the shakes just fine.
Post# 231279 , Reply# 50   8/18/2007 at 01:22 (6,086 days old) by gansky1 (Omaha, The Home of the TV Dinner!)
It looks like the basket is loose.
gansky1's profile picture
I think you have a problem with the universal joint or the splined drive block it's mounted to.
Post# 231308 , Reply# 51   8/18/2007 at 08:16 (6,086 days old) by jaxsunst ()
It is supposed to start cooling down some, so I can get into the garage and work without melting. I am going to take it apart and replace the u-joint and look at the block, and probably replace it too.
Post# 231337 , Reply# 52   8/18/2007 at 11:53 (6,086 days old) by andrewinorlando ()
You'll get her right....and you'll love that machine once it's fixed and working. Aside from the problem you're having getting it taken apart, it is actually very easy to work on. God only knows what its previous owners did to it or how they may have abused it. Mine has been an absolute workhorse for years, and a big timesaver, too.
Post# 231546 , Reply# 53   8/19/2007 at 13:36 (6,085 days old) by dadoes (TX, U.S. of A.)
I pulled my machine #2's u-joint this morn. No trouble at all getting the spanner nut off, u-joint and pulling the basket.
Post# 231652 , Reply# 54   8/19/2007 at 21:13 (6,084 days old) by andrewinorlando ()
Glenn - when you were whacking the spanner nut, did the whole works turn, as Jackson describes when he tried to remove his? Or does it stay put like I think mine did when I changed mine out. (I can't fully remember from when I did it.)
Post# 231659 , Reply# 55   8/19/2007 at 21:28 (6,084 days old) by dadoes (TX, U.S. of A.)
Nothing turned but the wrench and nut. I didn't even need to hold the basket still .. one hand to hold the wrench steady, the other to whack it with a mallet.
Post# 231710 , Reply# 56   8/20/2007 at 08:32 (6,084 days old) by andrewinorlando ()
That's what I thought I remembered!!! Thanks for confirming. At least now we know that Jackson has a problem with the machine and hopefully we can help figure out how to fix it!
Post# 232073 , Reply# 57   8/21/2007 at 22:02 (6,082 days old) by bundtboy ()
if it DOES turn out to be the tub...
that's covered by a lifetime warranty, is it not?
....maybe the tub is bent at the hub.
I hope it comes apart so we can find out~.
Did you try some penetrating grease on that nut? Also I never like whacking with rubber mallets. I use a 5 pound sledge for spanner nuts. Remember to hit it like you mean it, and it's lefty loosey.
What kind of hammer did you use, Glenn?
This may become one of our very rare machines in the future. I hope it all works out.
Good Luck.
b
Post# 232076 , Reply# 58   8/21/2007 at 22:09 (6,082 days old) by andrewinorlando ()
It's very, very painful to the ears to whack the spanner wrench with a non-rubber hammer inside of the stainless steel tub. The noise from the echo is painfully deafening, that's why you need the rubber mallet. The noise literally causes pain which is why the repair manual specifies the rubber mallet. I tried with a hammer...couldn't do it.
Post# 232161 , Reply# 59   8/22/2007 at 08:13 (6,082 days old) by bundtboy ()
very interesting
rubber mallet it is then.
Fool that I am, I bet I'd plug my ears and hit it with something harder.. could you put a matt in the tub to dampen the vibrations then give it a go?
Good luck.
b
Post# 232204 , Reply# 60   8/22/2007 at 13:44 (6,082 days old) by dadoes (TX, U.S. of A.)
Mallet. Hammer. Whichever. Not rubber. Perhaps partial-deafness helps deal with the noise ... although I really didn't notice much and only a few whacks were needed to get the nut off.
Post# 232225 , Reply# 61   8/22/2007 at 14:21 (6,082 days old) by bundtboy ()
5 lb sledge
That's exactly what I use. Mine was my grandfathers sledge hammer.
I hate it when crap doesn't come apart like it should.
b
Post# 232657 , Reply# 62   8/24/2007 at 17:27 (6,079 days old) by dadoes (TX, U.S. of A.)
I think I know what is Jackson's problem. His basket/hub is defective. The basket has slipped off-kilter on the hub, which is why it wobbles so badly during spin, and also why the entire u-joint is slipping when he tries to get the spanner nut loose.
I'm having the same problem now on Calypso #2 after getting it reassembled with the new u-joint. It was OK ... until I ran a test spin. The tub suddenly started wobbling/oscillating wildly at max spin speed, and now the basket is lopped off-center in the tub when stopped. Notice the balance ring is exposed on the left side of this pic and not on the right, and there's a gap on the right at the wash plate gasket.
Post# 232689 , Reply# 63   8/24/2007 at 21:36 (6,079 days old) by andrewinorlando ()
Sounds kosher to me! What do you do to fix it? Is that a basket replacement or u-joint replacement? Or something else.
Post# 232760 , Reply# 64   8/25/2007 at 12:19 (6,079 days old) by dadoes (TX, U.S. of A.)
Basket replacement. The hub is not separately replaceable AFAIK and U-joint has nothing directly to do with the problem. I disassembled my machine again yesterday evening. The basket is definitely loose from the hub, not exactly free-spinning but enough so that I can wriggle/turn it separately from the hub/U-joint fairly easily. Can't get the spanner nut loose as the entire hub turns (the brake isn't strong enough to hold it), so I'll have to cut the spanner nut off.
Post# 232780 , Reply# 65   8/25/2007 at 13:08 (6,079 days old) by andrewinorlando ()
Glenn - any idea how something like that happens? When you first got the machine, it was fine, wasn't it? I'm just curious, and like learning more about this machine, just in case!!
Post# 232796 , Reply# 66   8/25/2007 at 13:58 (6,079 days old) by dadoes (TX, U.S. of A.)
Andrew, I can't say about the machine initially being "fine" as I didn't run it prior to disassembly for clean-up. I didn't expect to find the u-joint bad, and it was ... the basket hub had surface corrosion but otherwise looked to be intact. If I had done only superficial clean-up without disassembly, who knows how long it would have run until the u-joint froze completely ... or if the basket would have eventually separated from the hub or not. It *had* to been on the verge of failure, as I couldn't have whacked the spanner nut *that* hard when reassembling to cause the trouble. I'm a weakling, LOL, I've been sitting at a desk job for 8 years and I don't do gyms!
The u-joint kit instructions say there are two kinds of basket hubs used, and each takes a specific spanner nut. The hub and spanner number have embossed part numbers. There's a chart in the instructions for matching them. One new spanner nut is included with the u-joint kit, and it was the right one to match my basket hub. Further, there are different tightening instructions for the two hub/nut combos. Mine instructed to tighten the nut finger-tight, then another 1 to 1-1/4 turns with the wrench -- 135 ft/lb torque. Interestingly, it says if replacing the basket at the same time, tighten it ANOTHER 1 to 1-1/4 (or 1-1/2?) turns!
This 2nd machine that looks cosmetically nearly pristine has turned into a serious headache. I suppose if one decides to break into a Calypso mechanism, one must be prepared to go the distance. Since the flange of the spanner nut protrudes below the hub threads into the u-joint, I may end up damaging the new u-joint when cutting the nut off and have to get another one.
A loose hub must be what is Jackson's trouble. Maybe not loose to the same degree, but with the same symptoms -- excessive oscillation during spin and the u-joint/hub turning when attempting to remove the spanner nut.
Post# 232891 , Reply# 67   8/26/2007 at 07:44 (6,078 days old) by jaxsunst ()
Good information, thanks. I will tear into it again when the heat index drops below 100.
Post# 234448 , Reply# 68   9/1/2007 at 14:35 (6,072 days old) by s2jrston ()
How did you remove the inner wash plate
How did you guys remove the inner wash plate?
Post# 234465 , Reply# 69   9/1/2007 at 17:09 (6,071 days old) by dadoes (TX, U.S. of A.)
Loosen and remove the outer wash dome by using two flat-blade screwdrivers 90° apart in two of the four slots provided.
The inner wash plate is the brown cone. Sort of a misnomer, but that's what it's called. On the original design it's white translucent plastic instead of brown. Remove the six 3/8" hex bolts that are exposed. When replacing the six bolts, they must be tightened in a specific pattern which is noted by numbers 1 thru 6 embossed on the inner wash plate dome.
Lift off the outer wash plate.
Lift off the inner wash plate. The leveler probably will "stick" to the bearing inside and come off with it. This will expose the nutate shaft protruding out of the spin drive tube and basket hub (not shown here). The nutate shaft fits into the splined opening on the leveler.
Remove the spanner nut, which holds the u-joint to the hub inside the basket. The u-joint then lifts off the hub, and the basket lifts off the spin drive shaft.
Post# 234528 , Reply# 70   9/2/2007 at 04:56 (6,071 days old) by s2jrston ()
Excellent answer. Thank you much. I ordered my u-joint kit and currently soaking the nut and threads with penetrating oil. The kit with spanner nut should be here mid week. My U-joint is brown with rust and covered with white fuzy soapy deposits. The leveler is brown with rust also. The shaft spline is in bad shape so I cleaned it and scraped the rust out of each groove. The main problem I had was that I didn't understand how to remove the inner dome. I finally figured it out by looking at this and one other thread. The dome was stuck to the u-joint and when I pulled on the dome edge it came loose. The leveler was stuck to the shaft. Thanks guys.
