Thread Number: 13274
ge clean sensor |
Post# 229943   8/12/2007 at 17:02 (6,098 days old) by lasvegasrox ()   |   | |
has aneyone ever seen or owned one of thease nedd more info thanks. :) |
Post# 230129 , Reply# 2   8/13/2007 at 06:38 (6,097 days old) by johnb300m (Chicago)   |   | |
Post# 230155 , Reply# 3   8/13/2007 at 08:46 (6,097 days old) by tomturbomatic (Beltsville, MD)   |   | |
IF any needed parts are still available and are reasonable in cost. |
Post# 230371 , Reply# 4   8/13/2007 at 23:56 (6,097 days old) by lasvegasrox ()   |   | |
8 spray things...must have ben alot of water pressure in those spray arms...i could only imagen being a dish and being scoured from top 2 bottom. |
Post# 230380 , Reply# 5   8/14/2007 at 00:41 (6,097 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I found one of these in stainless, removed the coins from the drain pump and resold it in a week. My sister has a non-sensor Profile model with the whirly-arm and 8 jets, never a dirty dish partly due to the filtering system - it is pretty good (aside from letting coins through ;-) A client has had the same dishwasher for 11 years and it still runs like new. It uses water, is reasonably fast and smart looking. |
Post# 230393 , Reply# 6   8/14/2007 at 02:10 (6,096 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 230537 , Reply# 7   8/14/2007 at 19:28 (6,096 days old) by johnb300m (Chicago)   |   | |
WOW. They don't even sell the multi-orbital spray arm anymore. PartSelect nor Repair Clinic have it listed anymore. Their solution is to replace it with a straight spray arm. Here's the drawing though... When I was a young kid I would pester GEAnswerCenter.com with emails every week. They told me the following about the wash system: "SmartWash System" 8 powerful jets yet with a gentle fan spray. The multi-orbital wash arm has 5 jets. 4 for dishes and one for the filter screen and driving the arm. The smaller spray arms rotate at 75 RPM with their jets fanning out at a 25deg. spray. The main arm spins with the small arms on each end at 30 RPM. The PowerTower sprays dishes with two 25deg. jets also, as well as the PowerShower sprayer on the top of the tub. Water passes through the sump screen and then the "soft food disposer" to the pump. The pump moves water through the system at 30 gallons per minute. Water falling through the machine randomly falls through the course screen in the top of the rear micro mesh filter and any food particles with it are strained out. The lower arm jet sprays at this filter to keep it clean and push food soil into the bottom collection chamber. During drain, the chamber seals, flushing soil out with the rest of the water. |
Post# 230557 , Reply# 8   8/14/2007 at 21:02 (6,096 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 231563 , Reply# 9   8/19/2007 at 15:31 (6,091 days old) by lasvegasrox ()   |   | |
lookie here |
