Thread Number: 13337
Hier Front Load Washer |
Post# 230803   8/15/2007 at 22:50 (6,097 days old) by pturo (Syracuse, New York)   |   | |
Is there a way to adjust the water level higher on this machine? I have it at a lake cottage with a pump from the lake so perhaps the timing is not in sync with the low water pressure? |
Post# 230817 , Reply# 1   8/15/2007 at 23:27 (6,097 days old) by pulsator (Saint Joseph, MI)   |   | |
The water pressure should not matter, the machine will fill until it's reached the appropriate water level, fast or slow. Only older solid tub toploaders filled with via time fill, nowadays all machines use pressure switches to tell when the washer is full of water, it can fill in 5 seconds or 15 minutes. Either way it will fill to the same level before advancing the timer.
Post# 230857 , Reply# 2   8/16/2007 at 06:16 (6,097 days old) by dascot (Scotland)   |   | |
Not necessarily true Pulsator - some basic FL machines have used a timed fill rather than pressure. Not sure which Haier machine this is, but it could be using that. |
Post# 230947 , Reply# 3   8/16/2007 at 13:26 (6,097 days old) by pulsator (Saint Joseph, MI)   |   | |
Post# 230997 , Reply# 4   8/16/2007 at 17:50 (6,096 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 230998 , Reply# 5   8/16/2007 at 17:51 (6,096 days old) by pulsator (Saint Joseph, MI)   |   | |
