Thread Number: 13479
look at this poor speed queen |
Post# 232851   8/25/2007 at 20:20 (6,060 days old) by hooverzodiac12 (Melbourne, Australia)   |   | |
i can't belive that they are still using it. it sounds horrible.
CLICK HERE TO GO TO hooverzodiac12's LINK |
Post# 232862 , Reply# 1   8/25/2007 at 21:46 (6,060 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 232870 , Reply# 2   8/25/2007 at 22:49 (6,060 days old) by hooverzodiac12 (Melbourne, Australia)   |   | |
Post# 232900 , Reply# 3   8/26/2007 at 09:05 (6,059 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 232919 , Reply# 4   8/26/2007 at 10:34 (6,059 days old) by johnb300m (Chicago)   |   | |
Post# 232943 , Reply# 5   8/26/2007 at 14:10 (6,059 days old) by lavamat78800 ()   |   | |
The owner got it not much time ago and knows that it´s broken. He´ll repair it. |
Post# 232996 , Reply# 7   8/26/2007 at 18:08 (6,059 days old) by goprog ()   |   | |
When I try watching it, it says it is a private video. Why can everyone else see it? |
Post# 233039 , Reply# 8   8/26/2007 at 20:26 (6,059 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
I know what is wrong The video settings have been changed from public to private unless u have a friend invite it is locked and friends are the only ones that can see it Go to my maytag dryer video the long one I set it to private it is now locked out CLICK HERE TO GO TO bpetersxx's LINK |
Post# 233041 , Reply# 9   8/26/2007 at 20:30 (6,059 days old) by goprog ()   |   | |
Yup - can't see your maytag dryer video either. Oh well. |
Post# 233078 , Reply# 10   8/26/2007 at 23:04 (6,059 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 233087 , Reply# 11   8/27/2007 at 00:31 (6,059 days old) by goprog ()   |   | |
Yes, the link works again. So if the owner changed it to private, how does he expect to get help analyzing the problem? (Rhetorical question.) |
Post# 233091 , Reply# 12   8/27/2007 at 01:14 (6,059 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
No it doesn't, it says I need an invite to see it. |
Post# 233100 , Reply# 13   8/27/2007 at 03:03 (6,059 days old) by goprog ()   |   | |
Sorry, I was referring to bpetersxx's LINK... I could get there again after he changed it back to public. |
Post# 233274 , Reply# 14   8/27/2007 at 18:31 (6,058 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Obviously something is not engaging in the machine...a brake or a clutch, something... I always though Speed Queens agitated appr. 180 degree strokes, but this one looks as if it does fewer strokes but several revolutions per stroke! Is it supposed to agitate like that or is that part of the problem too?
Post# 233284 , Reply# 15   8/27/2007 at 19:06 (6,058 days old) by queeny77 (BERWYN, ILLINOIS)   |   | |
Post# 233338 , Reply# 16   8/27/2007 at 22:22 (6,058 days old) by andrewinorlando ()   |   | |
Are you guys sure that's not a new transmission? I can see the brake pads, but the agitation in a single direction with rotating wash basket I think may need a new transmission. |
Post# 233375 , Reply# 18   8/28/2007 at 00:22 (6,058 days old) by geoff (Cape Coral, FL)   |   | |
My close friend has an AmanaTag of this design that had the same problem... This is what is happening.. There are 3 pads mounted to the baseplate of the machine. These are used for the brake after spin and to hold the tub in place while agitating.. What happened in his case is that he overloaded it so much that one of each of the two sets of screws holding the pads stripped..To do this repair you need a lot of patience and dexterity.. a new set of pads and screws is around $20 from a repair shop.. First off, unscrew and remove the bottom panel. after that is done, locate all of the screws holding the cabinet to the base and remove them.. once you have the cabinet at least partially removed, locate the fill flume and remove the hose attached at the back, next, remove the pressure dome on the left side of the tub. once all that is done and you have the cabinet off, you need to remove both hoses from the pump in order to be able to get to the right side brake pad...locate all of the screws and remove all three of the old brake pads.. Then just put the new ones on, screw them in tight and put the washer back together.. I do remember telling my friend that this was a one time repair.. If it happened again that I wasn't going to repair it again and that he should go buy a new set.. This wasn't a fun repair LOL.. Good luck with whatever you choose to do... Geoff |
