Thread Number: 13781
IGNIS! The pix |
Post# 237145   9/18/2007 at 13:28 (6,057 days old) by vivalalavatrice ()   |   | |
Here you are my dream machine finally and hardly found! |
Post# 237146 , Reply# 1   9/18/2007 at 13:30 (6,057 days old) by vivalalavatrice ()   |   | |
The top and the pushbuttons control panel... |
Post# 237147 , Reply# 2   9/18/2007 at 13:33 (6,057 days old) by vivalalavatrice ()   |   | |
Here you are! 8 cycles and red-to-stop, black-to-start The red led and the indicator...unfortunately not found... |
Post# 237149 , Reply# 3   9/18/2007 at 13:34 (6,057 days old) by vivalalavatrice ()   |   | |
Left (cold) for prewash, right (hot) for main wash... Now the machine is provided to work with a Y to fill with cold only |
Post# 237150 , Reply# 4   9/18/2007 at 13:35 (6,057 days old) by vivalalavatrice ()   |   | |
Opening the cabinet lid you will see that |
Post# 237151 , Reply# 5   9/18/2007 at 13:36 (6,057 days old) by vivalalavatrice ()   |   | |
and the outertub lid slide from left to right! |
Post# 237152 , Reply# 6   9/18/2007 at 13:36 (6,057 days old) by vivalalavatrice ()   |   | |
Post# 237155 , Reply# 9   9/18/2007 at 13:42 (6,057 days old) by vivalalavatrice ()   |   | |
Post# 237157 , Reply# 11   9/18/2007 at 13:48 (6,057 days old) by dj-gabriele ()   |   | |
Fantastico! Ti devo ancora una risposta decente per email! ;) I hope you're going to fix that machine for good! It'll be a marvel after the restoration! Never seen something similar anywhere else! |
Post# 237160 , Reply# 12   9/18/2007 at 14:21 (6,057 days old) by fa_f3_20 ()   |   | |
I can honestly say that I've never seen anything quite like that... |
Post# 237162 , Reply# 13   9/18/2007 at 14:47 (6,057 days old) by vivalalavatrice ()   |   | |
...without the panel...and rotatating! |
Post# 237163 , Reply# 14   9/18/2007 at 14:47 (6,057 days old) by vivalalavatrice ()   |   | |
Post# 237244 , Reply# 17   9/19/2007 at 00:53 (6,056 days old) by vivalalavatrice ()   |   | |
I really need some help to find the way to close and block the drum lids...Any suggests overthere?!? |
Post# 237258 , Reply# 19   9/19/2007 at 06:23 (6,056 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 237263 , Reply# 20   9/19/2007 at 07:16 (6,056 days old) by toggleswitch (New York City, NY)   |   | |
NICE MACHINE! In panel #237162 above, (the machine is siedways), is there a support "beam" that is supposed to be over the hub/bearings (center of tub)? The screw-holes on each side make me believe there is one not shown. I just assumed that horizontal axis machines of this type would always support both sides of the tub. |
Post# 237265 , Reply# 21   9/19/2007 at 07:17 (6,056 days old) by toggleswitch (New York City, NY)   |   | |
Post# 237319 , Reply# 24   9/19/2007 at 13:15 (6,056 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 237460 , Reply# 28   9/20/2007 at 07:28 (6,055 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
This is one cool looking machine, thanks for the pics so we can see it better. I'm sure you will not have any trouble with the tub-to-pump hose, a little silicone is a like a miracle for these machines. The Staber is an expensive machine for sure, but since each one is built (basically) by hand, the price is somewhat understandable. There are lots of other problems with the Staber washer that make it a bad deal though, not the least of which is the lack of any factory service network, the owner is expected to do the repairs themselves. |
Post# 237470 , Reply# 29   9/20/2007 at 08:09 (6,055 days old) by dj-gabriele ()   |   | |
gansky1: built by hand?! And no at-home technical service?? Ouch! |
Post# 237506 , Reply# 32   9/20/2007 at 13:13 (6,055 days old) by unimatic1140 (Minneapolis)   |   | |
WOW Diomede that is one beautiful machine!!! A big vintage Imperial Forum Congratulations! I have never seen a horizontal access top loader that has both an outer tub lid and an inner cylinder hatch. As for fixing leaks, that can be a real challenge that many of us have been through. Keep up the good work and don't worry about how it looks from the inside, the important thing is that the leak stops. You might have to try three or four different things but you'll get it, that washer is too beautiful not to come up with a solution! Please keep us posted. |
Post# 237557 , Reply# 33   9/20/2007 at 19:27 (6,054 days old) by funguy10 ()   |   | |
Also Staber wants YOU to fix the washer if it breaks. They have NO costomer service! |
Post# 237641 , Reply# 35   9/21/2007 at 07:42 (6,054 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hello Diomede Congratulations on finally getting your dream machine,looks in fine shape, luv the idea of removing the front access panel without undoing screws etc.. We had a similar machine here under the name of Stokvis, with the push buttons, and also a Philips but with a rotary timer.. I`m sure you will be an expert at fixing those leaks shortly, patience and a lot of bonding mastic will solve it I`m sure... enjoy, Mike |
Post# 238443 , Reply# 37   9/25/2007 at 16:19 (6,050 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 238598 , Reply# 39   9/26/2007 at 13:33 (6,049 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 238784 , Reply# 41   9/27/2007 at 09:02 (6,048 days old) by unimatic1140 (Minneapolis)   |   | |
