Thread Number: 13843
Frigidaire Dryer Drum Shaft |
Post# 238183 , Reply# 1   9/24/2007 at 08:42 (6,056 days old) by tomturbomatic (Beltsville, MD)   |   | |
Woodruff keys are generally available in the drawers of small hardware pieces below the screws at Lowes or at real hardware stores. |
Post# 238353 , Reply# 3   9/25/2007 at 07:23 (6,055 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Rich, you should see a slot in the drum shaft and a corresponding cut-out in the pulley center. If you have the shaft and pulley off the drum itself, take them to a local hardware store and try to find the correct woodruff key that fits your shaft and pulley. I only show one washer behind the pulley so it sounds like you have all the parts you'll need besides the key. Good luck! |
