Thread Number: 14063
IGNIS: IT WORKS! pix&vids are comin soon! |
Post# 241186 , Reply# 1   10/9/2007 at 03:58 (6,037 days old) by mielabor ()   |   | |
Congratulations with your successful repair. I am looking forward to the pictures. |
Post# 241189 , Reply# 2   10/9/2007 at 04:20 (6,037 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 241236 , Reply# 5   10/9/2007 at 12:28 (6,037 days old) by vivalalavatrice ()   |   | |
Amaze yourself! Here you are th two new inlet valves! |
Post# 241237 , Reply# 6   10/9/2007 at 12:30 (6,037 days old) by vivalalavatrice ()   |   | |
BLAST! They still have some drops! This will be the more difficult leak to stop...because you have to work cool but then there get whole hot! |
Post# 241238 , Reply# 7   10/9/2007 at 12:31 (6,037 days old) by vivalalavatrice ()   |   | |
Post# 241239 , Reply# 8   10/9/2007 at 12:32 (6,037 days old) by vivalalavatrice ()   |   | |
here it is! |
Post# 241240 , Reply# 9   10/9/2007 at 12:33 (6,037 days old) by vivalalavatrice ()   |   | |
here the control panel is! |
Post# 241241 , Reply# 10   10/9/2007 at 12:35 (6,037 days old) by vivalalavatrice ()   |   | |
Post# 241243 , Reply# 12   10/9/2007 at 12:39 (6,037 days old) by vivalalavatrice ()   |   | |
Post# 241245 , Reply# 14   10/9/2007 at 12:57 (6,037 days old) by panthera (Rocky Mountains)   |   | |
I am very happy for you. Don't worry about the leaks around the heating elements, hi-temp silicone will solve that problem. They do not get too hot around the connectors. Just be sure to clean the metal very well first (and be careful, even after all these years the edges of the tub will be very very sharp). Yes, you should get a higher temperature fill valve if you are going to fill it with hot water all the time. You don't have to use a twin pair, by the way. I should think the 3 minutes is more than enough unless you have very low water pressure. And even then, the cold water is cooling the valve. Keep us informed how it goes and thanks for the pictures. What a wonderful machine! |
Post# 241260 , Reply# 15   10/9/2007 at 13:41 (6,037 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 241269 , Reply# 16   10/9/2007 at 14:18 (6,037 days old) by vivalalavatrice ()   |   | |
Here's the first one... Can you hear the trrrrr of the timer going on!? The machine is heating that's why the red light lamp is on! |
Post# 241279 , Reply# 18   10/9/2007 at 14:55 (6,037 days old) by vivalalavatrice ()   |   | |
Post# 241284 , Reply# 19   10/9/2007 at 15:06 (6,037 days old) by funguy10 ()   |   | |
Could you do a full cycle video please? |
Post# 241286 , Reply# 21   10/9/2007 at 15:11 (6,037 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 241294 , Reply# 23   10/9/2007 at 15:59 (6,037 days old) by funguy10 ()   |   | |
I'm only 15. I have not been around for these pre-1985 washers. |
Post# 241483 , Reply# 27   10/10/2007 at 08:53 (6,036 days old) by vivalalavatrice ()   |   | |
I'm afraid |
Post# 241484 , Reply# 28   10/10/2007 at 08:59 (6,036 days old) by roto-tray-lover ()   |   | |
my compliments for this hard work! |
Post# 241486 , Reply# 29   10/10/2007 at 09:05 (6,036 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 241544 , Reply# 32   10/10/2007 at 13:10 (6,036 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hi Diomede, well done on getting your dream machine working, I love the sounds as it drives the wash basket along, was surprised to see the level of water, although that would have the "tradizionalisti di lavatrice" clapping their hands with glee!!! You had me gasping with your fingers near that cheese grater drum...Oohhh, careful as you go... It looks such a simple solid design, you can see why it still runs today, thank you for sharing your experience with us, enjoy, Mike |
