Thread Number: 14369
Maytag Model A212 Top Loader |
Post# 245315   10/30/2007 at 16:26 (6,016 days old) by daveb ()   |   | |
My washer will not fill with hot water. The inlet hose is clear, screen not clogged, and I have replaced the inlet valve. Any suggestions? |
Post# 245316 , Reply# 1   10/30/2007 at 16:29 (6,016 days old) by coldspot66 (Plymouth, Mass)   |   | |
Temperature switch could be bad. Maybe a wiring problem too. |
Post# 245338 , Reply# 2   10/30/2007 at 19:28 (6,015 days old) by toggleswitch (New York City, NY)   |   | |
Check to see if the hot solenoid is getting power when it should be. I'm assuming there is water coming to the solenoid valve. FIRST WE TURN OFF THE POWER........... If your reverse the "live" wires [most-likely NOT white, green or yellow] to the hot and cold solenoids, does the hot water now flow? (....just a reminder....... it should, in this temporary state, flow when "COLD" is selected, natch.) If hot still does not flow, but the cold does flow (when hot is selected) while the wires are still reversed, you may have a bad "neutral". Now reverse 'em back! |
