Thread Number: 14515
Dryer gets way too hot |
Post# 247159 , Reply# 2   11/8/2007 at 12:21 (6,007 days old) by pturo (Syracuse, New York)   |   | |
I would probably use some wd 40 spray on the area and a razor scraper. The WD will lube in so you wont scratch what is probably porcelin. Make sure you clean up the area good, you dont want traces of wd 40 spray in there, use a paper towel with some alcohol on it.(not paint solvent). |
Post# 247185 , Reply# 3   11/8/2007 at 15:26 (6,007 days old) by sherrys55caddy ()   |   | |
Thanks everyone for all the info I will take the advice and try it!!!! |
