Thread Number: 14584
Duet Fill Valve Leak |
Post# 247933   11/12/2007 at 12:58 (6,007 days old) by rp2813 (Sannazay)   |   | |
My 6+ month-old Duet HT washer has developed a problem with the fill valve not shutting off completely. Water will dribble out onto the boot, or onto the door glass which then routes it onto the floor unless I keep the door open enough for the protruding glass to clear the dripping. This can be just a few drops over the course of an hour, or when it's bad, it's nearly a constant dripping. I don't know if it's the hot or cold valve. I'm going to call in this repair once I know for sure that the machine is going to do this after every wash. Right now sometimes it doesn't. So is this a common weak spot with Duets? Anyone else have this problem? Ralph |
Post# 248022 , Reply# 1   11/12/2007 at 18:42 (6,007 days old) by appnut (TX)   |   | |
Post# 248209 , Reply# 2   11/13/2007 at 18:32 (6,006 days old) by rp2813 (Sannazay)   |   | |
