Thread Number: 14782
Kitchenaid imperial 21 questions |
Post# 250830 , Reply# 2   11/28/2007 at 11:55 (5,965 days old) by peteski50 (New York)   |   | |
Actually on the 19 and 20 series the water heater boosted the 1st water fill to 150. It wasn't until the 21 series that they went to 140 in the 1st fill. Even if the temperature is very hot going in the machine it may still heat for a few minutes anyway because the tank is initially cold. Also I always thought they should have had this heating in the main wash instead of the 1st fill. The main wash is heated at a lower watage to maintain the heat. It was 1400 wats for the 1st fill and 700 watts for circulating water in the main wash. Peter |
Post# 250853 , Reply# 4   11/28/2007 at 13:13 (5,965 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 250868 , Reply# 5   11/28/2007 at 14:33 (5,965 days old) by bobbyderegis (Boston)   |   | |
Sorry Mike. I was thinking Superba. But doesn't the Imperial have a Sani rinse as well? Your model has the timer dial. What do you mean it hums and then bypasses the rinse? Bobby in Boston |
Post# 250909 , Reply# 7   11/28/2007 at 17:21 (5,965 days old) by dadoes (TX, U.S. of A.)   |   | |
An Imperial with rapid-advance timer. Does the final rinse get skipped on all cycles - Normal, Pots & Pans, and China? Could be a glitch on the button array, or the timer ... either one causing the rapid-advance motor to trigger when it shouldn't ... maybe getting crossed-up somehow with the Rinse Hold sequence.
