Thread Number: 14913
Aqualtis Squeak - should I be worried? |
Post# 252484 , Reply# 2   12/6/2007 at 12:41 (5,957 days old) by dj-gabriele ()   |   | |
Call Hotpoint and ask about it, since it's a new machine they will provide all the necessary support if there's something that doesn't work as it should. |
Post# 252487 , Reply# 3   12/6/2007 at 13:06 (5,957 days old) by samsungfl (United Kingdom/London )   |   | |
Hi mrx, After settling with my Zanussi which had many little faults which I thought would "wear in" I wouldn't ever hesitate to call the manufacturer if something isnt quite right!, as in my experience they don't seem to wear in LOL, Or in my case just get worse and you end up ditching the machine!! Hope its nothing to serious! :) Richard |
Post# 252537 , Reply# 5   12/6/2007 at 16:11 (5,957 days old) by dj-gabriele ()   |   | |
Good service, at least for now, keep us informed! Ciaoo |
Post# 252783 , Reply# 8   12/8/2007 at 04:34 (5,955 days old) by chrisbsuk (Bristol, uk)   |   | |
Post# 252784 , Reply# 9   12/8/2007 at 05:10 (5,955 days old) by mrx ()   |   | |
Well, I was told they're sending a guy out and he'll have a new one in the van. Once he's checked the machine's genuinely faulty, it's a straight swap. |
Post# 252787 , Reply# 11   12/8/2007 at 05:12 (5,955 days old) by mrx ()   |   | |
Were the symptoms on your machine similar? Squeak ? |
Post# 252973 , Reply# 12   12/9/2007 at 05:18 (5,954 days old) by chrisbsuk (Bristol, uk)   |   | |
Post# 252981 , Reply# 13   12/9/2007 at 07:12 (5,954 days old) by mrx ()   |   | |
this one happens at about 800rpm then again as the machine slows to a stop after the spin there's a noise that sounds like something out of a horror movie door creaking :) |
Post# 253047 , Reply# 14   12/9/2007 at 13:34 (5,954 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Post# 253057 , Reply# 15   12/9/2007 at 14:19 (5,954 days old) by mrx ()   |   | |
Well, it's brand new this shouldn't be happening. so, I'm not holding off on a service call!!! |
Post# 253423 , Reply# 17   12/11/2007 at 13:47 (5,952 days old) by dj-gabriele ()   |   | |
Good, I'm pleased for you! Hopefully your new machine will be home soon and I'm sure you'll be even more satisfied after this experience! Also good to know about the tub and bearings! |
Post# 253620 , Reply# 18   12/12/2007 at 12:37 (5,951 days old) by mrx ()   |   | |
As promised, Machine's being replaced. Not only that, it's being replaced with the 8kg silver model, AQGD169S at no extra cost!! |
Post# 253646 , Reply# 20   12/12/2007 at 15:49 (5,951 days old) by mrx ()   |   | |
I donno what they were thinking with those stickers!! They should peel off. It seems like vandalism by the marketing department!! |
Post# 253740 , Reply# 22   12/13/2007 at 02:51 (5,950 days old) by mrx ()   |   | |
what is the triangular bit on the door seal all about? I've seen it on a few newer machines, including aqualtis |
Post# 254050 , Reply# 24   12/14/2007 at 07:04 (5,949 days old) by mrx ()   |   | |
Ah right, our older miele tends to get socks stuck on the door a lot! |
Post# 254052 , Reply# 25   12/14/2007 at 07:09 (5,949 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
