Thread Number: 15032
Neptunes doing their job |
Post# 254336   12/15/2007 at 17:06 (5,948 days old) by spaniel50 ()   |   | |
The Maytags are doing the Saturday laundry. |
Post# 254339 , Reply# 1   12/15/2007 at 17:08 (5,948 days old) by funguy10 ()   |   | |
More pictures? |
Post# 254372 , Reply# 2   12/15/2007 at 19:26 (5,948 days old) by spaniel50 ()   |   | |
doors open |
Post# 254381 , Reply# 3   12/15/2007 at 20:10 (5,948 days old) by funguy10 ()   |   | |
How about showing loads as they go in and out, what you set the controls at, the insides of the machines, etc. |
Post# 254387 , Reply# 4   12/15/2007 at 20:24 (5,948 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 254398 , Reply# 5   12/15/2007 at 21:25 (5,948 days old) by pulsator (Saint Joseph, MI)   |   | |
Who needs a window? Just wash with the door open! That's what I do with mine! However, one does half to watch the size of the load, too small and the water will splash out, too big and corners of things will flop out between tumbles, but a medium load will neither splash nor flop out, the angle of the drum holds everything in! YAY!
Post# 254401 , Reply# 6   12/15/2007 at 21:38 (5,948 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 254433 , Reply# 7   12/16/2007 at 00:53 (5,948 days old) by sudsmaster (SF Bay Area, California)   |   | |
I've gotten to where I can tell, by ear, if the load is too sudsy. The sloshing will sound muffled by the suds. An open detergent cover will asisst in that determination. While a very sudsy load might dribble a bit on the floor, the angled drum also seems to minimize that as well. The machine also has an effective suds reduction feature that will do drains and rinses until the offending froth is reduced to manageable levels. On the 7500, the screen will clearly show "Suds Rinse" to let you know what it's doing. My usual tactic is to add a bit less detergent than I think might be needed. I'll then open the door and check for suds and slipperyness. I'll add a bit more detergent until a hint of suds appears and the water is slippery. A window wouldn't help determining slipperyness. The door action on the 7500 is also fairly prompt, so opening it to check on things isn't that big a deal. |
Post# 254475 , Reply# 8   12/16/2007 at 09:27 (5,947 days old) by spaniel50 ()   |   | |
Sunday morning with sheets and towels to be washed. These are the most versitle machines. No more unbalanced loads! |
Post# 254480 , Reply# 9   12/16/2007 at 10:03 (5,947 days old) by funguy10 ()   |   | |
How can you watch a Front-Loader with the door open? I don't think that would be a good idea. |
Post# 254482 , Reply# 10   12/16/2007 at 10:19 (5,947 days old) by spaniel50 ()   |   | |
Setting for the washer |
Post# 254484 , Reply# 11   12/16/2007 at 10:31 (5,947 days old) by spaniel50 ()   |   | |
washer settings |
Post# 254485 , Reply# 12   12/16/2007 at 10:32 (5,947 days old) by johnb300m (Chicago)   |   | |
Post# 254496 , Reply# 13   12/16/2007 at 12:16 (5,947 days old) by pulsator (Saint Joseph, MI)   |   | |
