Thread Number: 15052
New Whrilpool Duet WFW9200SQ |
Post# 254735 , Reply# 1   12/17/2007 at 14:59 (5,968 days old) by funguy10 ()   |   | |
Do you have any pictures or videos to post from the cycle? |
Post# 254785 , Reply# 2   12/17/2007 at 18:31 (5,968 days old) by appnut (TX)   |   | |
Post# 254957 , Reply# 3   12/18/2007 at 07:56 (5,968 days old) by seeitrun2006 (Commerce, GA)   |   | |
Hey Funguy, Let's see some pic's of your laundry appliances! You want to see a picture of my machine go to the link I have attached. I just don't have time to take any pic's at the moment. CLICK HERE TO GO TO seeitrun2006's LINK |
Post# 254973 , Reply# 4   12/18/2007 at 09:48 (5,967 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 258820 , Reply# 5   1/9/2008 at 12:34 (5,945 days old) by rp2813 (Sannazay)   |   | |
I thought my Duet only heated the water for the Sanitary cycle but have since read up in the manual and saw that it also will heat the water on the Heavy Duty cycle, but I presume not to the same temp as is used for Sanitary. I don't use bleach very often when I wash my white loads so instead of the Whitest Whites cycle which basically just provides an extra rinse to get all of the bleach out, I use the Heavy Duty cycle since it will keep the hot water hot.
Post# 259010 , Reply# 6   1/10/2008 at 09:22 (5,945 days old) by seeitrun2006 (Commerce, GA)   |   | |
This Duet has the automatic temperature control. I really like that feature since our hot water heater is about 35 feet from the washer. |
Post# 259018 , Reply# 7   1/10/2008 at 10:36 (5,944 days old) by rp2813 (Sannazay)   |   | |
Right, but I think the Duet still wants incoming water to be at least 120 degrees in order for the on board heater to bring it up to proper washing temperature. Mine is only about 6' from the water heater but I often will run the hot water at the laundry sink first. These machines use so little water compared to a top loader that I feel even a small amount of cold water could throw things off.
Post# 259028 , Reply# 9   1/10/2008 at 13:11 (5,944 days old) by tlee618 ()   |   | |
I can see where this could really save the water but just wondering if you have noticed an increase in electric or gas usuage because of it? I have an electric water heater. |
Post# 259035 , Reply# 10   1/10/2008 at 15:00 (5,944 days old) by funguy10 ()   |   | |
Okay, seeitrun2006, Here is your washer captured with the magic of Alt+Print Screen and Cut+Paste. |
Post# 259170 , Reply# 11   1/10/2008 at 23:07 (5,944 days old) by appnut (TX)   |   | |
Post# 259214 , Reply# 13   1/11/2008 at 06:09 (5,944 days old) by seeitrun2006 (Commerce, GA)   |   | |
Funguy10, I really appreciate you taking the time to post the wonderful picture of my Whirlpool Duet HT. You are da man! You rock dude! Still waiting on you to send pictures, videos etc. of YOUR laundry appliances! |
