Thread Number: 15189
problem with 1960's Maytag washer |
Post# 256512 , Reply# 1   12/27/2007 at 18:29 (5,957 days old) by coldspot66 (Plymouth, Mass)   |   | |
You need to replace the rubber insert and what's inside it. Also replace the plastic outer shell with the vent holes. There is a kit with all necessary parts and a new hose from the inlet valve to this injector assembly. Part # is 204660. |
Post# 256538 , Reply# 3   12/27/2007 at 20:50 (5,957 days old) by coldspot66 (Plymouth, Mass)   |   | |
The injector assembly prevents gray water ( should the tub overflow) from backing up into the hose where fresh water exits, so as not to contaminate it. |
