Thread Number: 15284
Maytag Electronic Dry DG906 Question |
Post# 257551 , Reply# 1   1/3/2008 at 20:56 (5,954 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Grounding seems to be essential on electronic sensor 'Tags- my own DE606 doesn't work correctly if it's not grounded. And it's a much simpler machine than yours. Since you do have a ground wire attached to the cabinet (are you using the factory ground screw, or some other screw?), your outlet may be somehow at fault, but I'll leave that to mightier minds than my own. |
Post# 257553 , Reply# 2   1/3/2008 at 21:22 (5,954 days old) by toggleswitch (New York City, NY)   |   | |
~ Have a ground wire from the very bottom of the cabinet in back attached to a cold water pipe. Assuming all works as it should (and that paint is not insulating the ground wire from the cabinet) this effectively grounds the outlet, even if it is improperly (or is no longer) grounded through its own wiring. |
Post# 257576 , Reply# 3   1/4/2008 at 00:01 (5,954 days old) by pturo (Syracuse, New York)   |   | |
I assume it is the factory ground screw,but I am wondering if that is overrided by the 3 prong to the outlet. Toggles has a point, I painted the back of the cabinet, but to my original question, could I ground the cabinet anywhere? |
Post# 257582 , Reply# 5   1/4/2008 at 00:53 (5,954 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
With the dryer empty, press the damp-dri button to start the machine. It should shut off within 20-30 seconds if the electronic control is working properly. If it does shut off within that timeframe, we'll go on to step two... You can ground the cabinet anywhere - and it should be fine the way you have it. I've used quite a few of these HOH dryers w/electronic control with the cabinet not grounded and they worked just fine. |
Post# 257622 , Reply# 6   1/4/2008 at 08:36 (5,954 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Have you cleaned the sensors in the drum? |
Post# 257682 , Reply# 8   1/4/2008 at 14:43 (5,953 days old) by volvoguy87 (Cincinnati, OH)   |   | |
Go to the hardware store and in the home electrical section you can buy an inexpensive outlet tester. It plugs into your outlet and has 3 lights on it. The lights will come on in a sequence according to how your outlet is wired. By checking the displayed lights against the key on top of the tester, you can determine if your outlet is properly grounded, and properly wired otherwise. Also, make sure that the water pipe is actually grounded. If there's a plastic connection between sections of pipe somewhere, it may not be grounded. Good luck, Dave |
Post# 257684 , Reply# 9   1/4/2008 at 14:48 (5,953 days old) by bobbyderegis (Boston)   |   | |
Phil, the loose connections on the electronic control could be your problem. I had to solder the connections on my 606. Did you consider replacing the electronic control as well? Bobby in Boston |
Post# 257691 , Reply# 10   1/4/2008 at 15:50 (5,953 days old) by pturo (Syracuse, New York)   |   | |
Bobby, This is a new electronic control(1 year) But the wires seem to fit very loosely. Dave, Thanks for the tip. Never hurts to have an outlet tester. Phil |
Post# 257814 , Reply# 14   1/5/2008 at 06:38 (5,953 days old) by toggleswitch (New York City, NY)   |   | |
Using a standard neon tester to check for earth/ground. I'm sure most of us understand sticking one lead into the hot opening of an outlet /power-point, and the other in the ground opening should cause the tester to light. Here is what you may not know (although it may be safe and possible........I CAN NOT recommend this on 230v....) WITH THIS TYPE OF TESTER ONLY..... one lead may be stuck in the hot side of an outlet and the other lead may be allowed to make contact WITH YOUR VERY OWN FINGER. You will get the thing to partialy light up. This is useful to ensure that you have actually made contact witht the "hot/live" lead should the outlet not have a neutral or a good ground enabling you to light it up otherwise. REMEBER: THIS PROCEDURE IS FOR A "NEON" NOT A REGULAR LAMP / LIGHT BULB TESTER! |
Post# 257815 , Reply# 15   1/5/2008 at 06:45 (5,953 days old) by toggleswitch (New York City, NY)   |   | |
Post# 257915 , Reply# 17   1/5/2008 at 16:12 (5,952 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 257917 , Reply# 18   1/5/2008 at 16:13 (5,952 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 257918 , Reply# 19   1/5/2008 at 16:13 (5,952 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 258023 , Reply# 20   1/6/2008 at 00:28 (5,952 days old) by pturo (Syracuse, New York)   |   | |
Thanks Gansky, What a great and thoughfully accurate contribution. |
Post# 258024 , Reply# 21   1/6/2008 at 00:33 (5,952 days old) by pturo (Syracuse, New York)   |   | |
Post# 258570 , Reply# 23   1/8/2008 at 07:00 (5,950 days old) by bobbyderegis (Boston)   |   | |
Phil: one loose connection to the electronic control and it's a freak show. Try the new harness. Bobby in Boston |
Post# 258901 , Reply# 24   1/9/2008 at 18:58 (5,948 days old) by pturo (Syracuse, New York)   |   | |
New harness on order, and thanks Bobby. |
Post# 258991 , Reply# 25   1/10/2008 at 06:54 (5,948 days old) by bobbyderegis (Boston)   |   | |
Phil, I'm surprized you can still get them. Is it new? Bobby in Boston |
