Thread Number: 15701
Found Kenmore Calypso |
Post# 263501 , Reply# 1   2/5/2008 at 23:34 (5,921 days old) by john36 ()   |   | |
here it is all apart |
Post# 263502 , Reply# 2   2/5/2008 at 23:37 (5,921 days old) by john36 ()   |   | |
here is the outer tub all cleaned up |
Post# 263503 , Reply# 3   2/5/2008 at 23:41 (5,921 days old) by john36 ()   |   | |
all back together! I was surprised how easy this washer was to take apart. |
Post# 263513 , Reply# 4   2/6/2008 at 00:36 (5,921 days old) by dadoes (TX, U.S. of A.)   |   | |
Be aware that service specifications require the u-joint seals be replaced *every time* it's disassembled -- the pink o-ring atop the basket hub under the u-joint (if the u-joint is pulled), and the six grommets atop the u-joint under the inner dome. The lid switch can be bypassed by tapping a jumper across the connection block. I added a Toggleswitch® to one of mine. Toggle On, lid switch bypassed. Toggle Off, lid switch works normally. The lid switch must be opened at the end of a cycle (or the power cord unplugged) to reset it for another cycle, adding the Toggleswitch® faciliates that operation. |
Post# 263540 , Reply# 5   2/6/2008 at 07:27 (5,920 days old) by jaxsunst ()   |   | |
I have that identical machine. We have been using it for several months now and love it. |
Post# 263541 , Reply# 6   2/6/2008 at 07:31 (5,920 days old) by tlee618 ()   |   | |
Jon, what a great find! You have that machine looking like new! |
Post# 263578 , Reply# 7   2/6/2008 at 13:52 (5,920 days old) by tuthill ()   |   | |
Really lucky you found such a new and nice machine! |
