Thread Number: 15750
Wringer-Flo? |
Post# 264243   2/10/2008 at 14:19 (5,916 days old) by historyman (Pittsburgh, PA/Aiken, SC)   |   | |
Here's my idea for a "Wringer-Flo": Take a wringer washer with a pump. Place a nylon mesh material (pantyhose) over the drain hose end. Place hose so water is redirected back into the tub. Now, will this work? Would the pump motor be damaged/destroyed as it's not designed to run like this? Will the transmission even allow for the pump and the agitator to be running at the same time? Thoughts? |
