Thread Number: 15761
Frigidaire Pro Series Dishwasher |
Post# 264324   2/10/2008 at 19:19 (5,918 days old) by laundromat (Hilo, Hawaii)   |   | |
I found this on EBAY and got it for $129+$119for delivery.When I got it and installed it,it ran up to the last rinse then took a shit.I called for service and the motor for recirculating the water burned out.They replaced it and found broken glass and two of the instalation screws in it which blocked it causing it to burn out.It ran fine for one cycle then,somehow,the bottom spray arm went out of joint and kept falling off.I looked and saw a very small half svere shaped filter on the base of the tub.I took it out and called for service again.They came out and showed me what happened and fixed it again.Now, so far,it runs great and realy does a great job in cleaning and drying.It's very quiet and has lots of useable space.I can run either the upper or lower racks alone or both at the same time.I had a little get together with some friends from the gym I go to and had lots of glasses and saucers to wash.They all fit in the upper rack so,I set it to wash by itself and got great results!I did however get the 3 year extension on my warranty.
Post# 264326 , Reply# 1   2/10/2008 at 19:21 (5,918 days old) by laundromat (Hilo, Hawaii)   |   | |
