Thread Number: 1589
Kenmore Has me Stumped |
Post# 60644 , Reply# 2   3/19/2005 at 20:48 (6,948 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 60652 , Reply# 3   3/19/2005 at 22:09 (6,948 days old) by fixerman ()   |   | |
Coldspot66,I don'think you are veering at all. That was my first thought too. Anyway the water valve or it's controls are likely suspects here and the next thing to check. |
Post# 60660 , Reply# 4   3/19/2005 at 23:10 (6,948 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 60673 , Reply# 5   3/20/2005 at 06:11 (6,948 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 60690 , Reply# 10   3/20/2005 at 11:29 (6,948 days old) by Unimatic1140 (Minneapolis)   |   | |
I the washer fills for the rinse and the motor is started when the proper water level is reach (water temperature is not a factor only water level) I would guess it would be the Control Magnet Assembly (wig-wag) BUT since the shifter cam bars seem to work fine for the wasy cycle this would only leave the timer left as the cluprit. The timer cam for the agitate solenoid (and possible spin solenoid too) might be misaligned or worn down even and its not making the connection properly during the rinse. If it works for the wash, it should work for the rinse then. I'm sure there is no difference in wiring between wash and rinse mode for the mechanical features such as the motor, agitator and extractor cam solenoids. |
Post# 61296 , Reply# 14   3/25/2005 at 11:43 (6,943 days old) by DADoES (TX, U.S. of A.)   |   | |
