Thread Number: 16061
GE Versatronic Washer |
Post# 268174 , Reply# 1   3/6/2008 at 16:14 (5,893 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 268178 , Reply# 2   3/6/2008 at 17:10 (5,893 days old) by filterflo (Chicago Area)   |   | |
Ok Mike, time for another set of pics of your beautiul HarvestGold Versatronic set....... |
Post# 268216 , Reply# 3   3/6/2008 at 23:10 (5,893 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 268360 , Reply# 4   3/7/2008 at 19:36 (5,892 days old) by bajaespuma (Connecticut)   |   | |
Post# 268458 , Reply# 5   3/8/2008 at 11:31 (5,891 days old) by keithelong ()   |   | |
Yes the "8" in the Model Number designated an 18lb washer. |
Post# 268508 , Reply# 7   3/8/2008 at 18:29 (5,891 days old) by gewa1054wguy ()   |   | |
Here are the controls. |
Post# 268509 , Reply# 8   3/8/2008 at 18:30 (5,891 days old) by gewa1054wguy ()   |   | |
Here are the timer settings: |
Post# 268510 , Reply# 9   3/8/2008 at 18:30 (5,891 days old) by gewa1054wguy ()   |   | |
Here is the tub. Note the turquoise color of the speckles. |
Post# 268511 , Reply# 10   3/8/2008 at 18:32 (5,891 days old) by gewa1054wguy ()   |   | |
Here is the agitating action of the straight vane. I also use a V14 ramp agitator for better full load turn-over. |
Post# 268512 , Reply# 11   3/8/2008 at 18:33 (5,891 days old) by gewa1054wguy ()   |   | |
Famous Filter flow action. |
Post# 268513 , Reply# 12   3/8/2008 at 18:33 (5,891 days old) by gewa1054wguy ()   |   | |
Here is the dryer, note the same turquoise speckles inside. |
Post# 268514 , Reply# 13   3/8/2008 at 18:34 (5,891 days old) by gewa1054wguy ()   |   | |
Here are the timer options. |
Post# 268515 , Reply# 14   3/8/2008 at 18:51 (5,891 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
That is such a stunning set!!! Question regarding the Jet-Swirl softener dispenser: From what I gathered when using mine, the washer spin the softener into a reservoir at the base of the dispenser to prevent it from draining onto garments in the wash-tub prior to filling. It looks like the only way it dispenses is by water splashing up into it from the recirculating water in the filter-flo pan. That means there's going to be water (and some softener possibly) left in there until the final spin. Is that just going to be thrown out all over the insides of the wash tub, etc.? I wasn't too satisfied so i took it out and dumped the rest out before the spin. Just curious about how it SHOULD work. Thanks! Jon |
Post# 268518 , Reply# 15   3/8/2008 at 19:15 (5,891 days old) by filterflo (Chicago Area)   |   | |
Love seeing this set Mike, and Im so glad you gave these cast off's a good home! Good home? Why, with you its the best! |
Post# 268525 , Reply# 16   3/8/2008 at 20:30 (5,891 days old) by appnut (TX)   |   | |
Post# 268545 , Reply# 17   3/8/2008 at 21:56 (5,891 days old) by frigilux (The Minnesota Prairie)   |   | |
