Thread Number: 1622
Maytag Neptune Commercial Washers |
Post# 61085 , Reply# 1   3/23/2005 at 17:44 (6,944 days old) by kenmore1978 ()   |   | |
Strange, you would think a laundromat owner would WANT rinses to be cold to cut down on water heating bill |
Post# 61160 , Reply# 5   3/24/2005 at 13:11 (6,943 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 61179 , Reply# 6   3/24/2005 at 16:05 (6,943 days old) by PeterH770 (Marietta, GA)   |   | |
Your commercial Neptunes are warm rinsing because someone set them to warm rinse in the control board. Warm rinse is an owner programable option. Let your student services department know and they will have someone reset the option. Also, could it be that because of the route the water takes to get to your building that it could be picking up ambient heat? We had that issue in my dorm. The school used steam heat, and the steam and water pipes all traveled thru the same tunnels, so the cold water pipes would pick up heat from the tunnels and end up warm at the tap. Could it also be that the suppy hoses for the washers are conneced backwards? |
Post# 61198 , Reply# 7   3/24/2005 at 19:51 (6,943 days old) by Repair-man (Pittsburgh PA)   |   | |
I know that on the residential machines you can't connect the hoses backwards. The machine will quickly correct itself by reversing the hot and cold valves. I would think that even backwards hoses would have no effect on warm water Ed |
Post# 61211 , Reply# 8   3/24/2005 at 20:46 (6,943 days old) by tolivac (greenville nc)   |   | |
since the machine has electronic controls-couldn't it sense the hoses are reveresed and tell you on its display-like"check water connections" |
Post# 61255 , Reply# 9   3/25/2005 at 06:20 (6,943 days old) by Repair-man (Pittsburgh PA)   |   | |
It can sense if they are backwards. But instead of telling you it just switches the cold valve to hot, etc. |
Post# 61285 , Reply# 10   3/25/2005 at 10:45 (6,942 days old) by Joe_In_Philly (Philadelphia, PA, USA)   |   | |
