Thread Number: 16251
Dishwasher GE Permatuf Potscrubber 600 with temp. sensor |
Post# 270481 , Reply# 1   3/18/2008 at 10:48 (5,876 days old) by pdub (Portland, Oregon)   |   | |
Does it sound like the pump is running when it is supposed to be draining? You might check where the drain hose connects to the garbage disposal and make sure that connection isn't clogged. Sometimes food waste will plug the opening. Loosen the clamp where the hose connects and check for blockage. The liquid plumber would not get up to that point to do any good and I also think that might be a bit strong to use in a dishwasher. Good Luck.
Post# 270490 , Reply# 2   3/18/2008 at 11:57 (5,876 days old) by coldspot66 (Plymouth, Mass)   |   | |
Does this model have the filter screen on the back wall at the bottom? If so, remove it with 4 screws, I think, and unscrew the piston & nut assembly. The rubber stopper wears away and lets water recirculate back into the bottom of the tub. Hope this helps! |
