Thread Number: 16272
GE Filter-Flow Mechanical Question |
Post# 270749 , Reply# 2   3/19/2008 at 16:27 (5,853 days old) by pturo (Syracuse, New York)   |   | |
Thanks,Gyrofoam! |
Post# 270753 , Reply# 3   3/19/2008 at 16:33 (5,853 days old) by unimatic1140 (Minneapolis)   |   | |
wait a minute, is the transmission pulley turning counterclockwise via the belt/motor but the tub is not moving??? Is there a water save button on the control panel? If so set the dial to wash and pull it out, press the water saver button and the washer should start to agitate, does the agitator go back and forth? |
Post# 270797 , Reply# 5   3/19/2008 at 18:54 (5,852 days old) by unimatic1140 (Minneapolis)   |   | |
Yes don't put any water in it yet. Plug the machine in and put the dial to a wash time like 8 or 10. Pull the dial out and the water valve solenoid(s) will buzz, then PRESS and hold the Water Saver Button for one second and the washer will begin to agitate (meaning the motor will turn the belt in a clockwise direction). See what it does and let us know.
Post# 270808 , Reply# 6   3/19/2008 at 19:42 (5,852 days old) by pturo (Syracuse, New York)   |   | |
Thanks again, Robert, that will be my next diagnostic when I get over to my sisters house again this week. |
Post# 270942 , Reply# 7   3/20/2008 at 12:06 (5,852 days old) by spinout (Phoenix)   |   | |
Can the outer tub be moved by hand? Sounds like the spin clutch spring isn't grabbing the spin tube or the tub is frozen. |
Post# 270980 , Reply# 9   3/20/2008 at 14:58 (5,852 days old) by unimatic1140 (Minneapolis)   |   | |
That is totally fabulous Philip, now get some really hot water into the outer tub (use a hose connected to the sink) and let the filter-flow system pump it up into the wash tub (setting the dial to a wash time again and pressing the water saver button). Then spin it out and connect the washer to water. Give it a full test and let us know what you find.
