Thread Number: 16318
is there quick fix for "pipe knock" ?? |
Post# 271421 , Reply# 2   3/22/2008 at 14:04 (5,869 days old) by mielabor ()   |   | |
Look in the thread "How are your appliances connected" in the "Super" forum. Toggleswitch has installed a wonderful solution for that problem that can easily be duplicated using standard plumbing materials. |
Post# 271508 , Reply# 4   3/23/2008 at 02:44 (5,869 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 271591 , Reply# 5   3/23/2008 at 11:34 (5,869 days old) by toggleswitch (New York City, NY)   |   | |
~Toggleswitch has installed a wonderful solution for that problem that can easily be duplicated using standard plumbing materials. A pressure reducrer can be installed to reduce the whole house's water pressure (BOO HISS MOAN!) Or store-bought water-hammer silencers (in the form aor sealed air-chambers can be bought. If you have that Italian disease that comes to me so often (Fundz-are-lo) you can make these yourself with a 9 to 12 inch lenght of pipe (which is bigger than it sounds, trust me!) and two caps. A small expansion tank with a (rubber or plastic diaphragm within) located jsut after the hot water heater on the "hot" water line can't hurt either. |
