Thread Number: 1643
KitchenAid dishwasher dilema |
Post# 61294 , Reply# 1   3/25/2005 at 11:29 (6,942 days old) by coldspot66 (Plymouth, Mass)   |   | |
Is the detergent cup blue or white? The round white one is no longer available from K/A. Could be the bimetal that controls the cup is bad or a burnt wire going to it. Let me know, maybe I can help. |
Post# 61297 , Reply# 2   3/25/2005 at 11:52 (6,942 days old) by dalangdon (Seattle, WA)   |   | |
it's a white cup. I had orginally assumed that the snap mechanism was just clogged or something, but it seems like it might be more than that. I will investigate tonight. |
Post# 61308 , Reply# 3   3/25/2005 at 13:49 (6,942 days old) by GadgetGary (Bristol,CT)   |   | |
I have a KA KUDS220T with a white soap dispenser. The prewash cover has no spring back. The wash portion works perfectly. There really isn't a problem since the prewash simply snaps open after initial water heating to release the detergent. The only problem is if I use the Soak 'n Scrub cycle. This supposedly requires three detergent fills. But I have just used the two and have not had a problem. Don't know if I should try to have it repaired. It really has not affected its performance. Gary |
