Thread Number: 16493
Which compact stackable to buy? |
Post# 273613 , Reply# 1   4/3/2008 at 16:07 (5,864 days old) by toggleswitch (New York City, NY)   |   | |
Do you have 220v avaialable? What amperage? If you are limited to 110v, a standard full-sized 27" x 27" Frigidaire dryer with ELECTRONIC dryness controls (and the controls located in the front) can be stacked. It can also easily be converted to 110v., at little to no cost. Of course, it will still take forever-and-a-day to dry and you may have to put it in a room with a window and a window fan to pull out the humidity. |
Post# 273775 , Reply# 3   4/4/2008 at 13:45 (5,863 days old) by nmaineman36 ()   |   | |
If you want to spend the money on a good compact set then I would go with a Miele system. Depending on how much room you have to play with I would go with the Miele's...you cant go wrong. |
