Thread Number: 16618
Frigidaire 1-18 revitalization project Pt 2 |
Post# 274896 , Reply# 2   4/12/2008 at 23:22 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
Outer tub |
Post# 274897 , Reply# 3   4/12/2008 at 23:28 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
some rust How do I best fix this. clean it with wire brush, or chemicals? And then with what do I coat it, porcelin repair goop?? |
Post# 274898 , Reply# 4   4/12/2008 at 23:32 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
This thing has a unusual drain sump. |
Post# 274899 , Reply# 5   4/12/2008 at 23:33 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
The tub seal shows no obvious problems |
Post# 274900 , Reply# 6   4/12/2008 at 23:37 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
So easy to get to everything, once it's upside down. |
Post# 274901 , Reply# 7   4/12/2008 at 23:42 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
Side view of motor model S67PXENY-5181 H.P. 1/2B 115 volts 9.0 amp 60hz, R.P.M. 1725/1140 Thermally Protected Made in U.S.A. |
Post# 274902 , Reply# 8   4/12/2008 at 23:45 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
Simple sheve pulley on motor and on drive shaft. good for Tim Taylor hopping up. |
Post# 274903 , Reply# 9   4/12/2008 at 23:47 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
view of spin roller, for those who might wonder "how did that thing go on...?" Hard to see it from this angle installed in a cabinate. |
Post# 274904 , Reply# 10   4/12/2008 at 23:48 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
another view of roller |
Post# 274905 , Reply# 11   4/12/2008 at 23:50 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
How to get the agitate shaft out? Remove it thru the hole in the bottom... |
Post# 274906 , Reply# 12   4/12/2008 at 23:51 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
What hole? Oh that hole |
Post# 274907 , Reply# 13   4/12/2008 at 23:53 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
...and up |
Post# 274908 , Reply# 14   4/12/2008 at 23:54 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
and out find what's wrong with this picture.. |
Post# 274909 , Reply# 15   4/12/2008 at 23:55 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
How nasty can an agitate shaft get? |
Post# 274910 , Reply# 16   4/12/2008 at 23:57 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
Wear zones on agitate shaft, 2 areas on either end. This is why I'd like to lube it lightly. not drippy, just wipe on. |
Post# 274911 , Reply# 17   4/12/2008 at 23:58 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
close up of upper wear zone and keyway made with key cutter wheel. |
Post# 274912 , Reply# 18   4/12/2008 at 23:59 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
closeup of lower wear zone, end which attaches to agitate coupler. |
Post# 274913 , Reply# 19   4/13/2008 at 00:02 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
Tub seal, inner tub side |
Post# 274914 , Reply# 20   4/13/2008 at 00:04 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
The spin brake was a bit wobbly. Is it supposed to be wobbly? The juice around the bronze bushing is from liquid wrench sprayed onto the tub nut to help get it off. |
Post# 274915 , Reply# 21   4/13/2008 at 00:06 (5,855 days old) by fltcoils (South Bend, Indiana)   |   | |
Hoses, a maze of hoses. Anyone ever get confused and wonder which went where? |
Post# 274924 , Reply# 23   4/13/2008 at 03:16 (5,855 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 274928 , Reply# 24   4/13/2008 at 06:08 (5,855 days old) by panthera (Rocky Mountains)   |   | |
Post# 274936 , Reply# 25   4/13/2008 at 08:14 (5,855 days old) by laundromat (Hilo, Hawaii)   |   | |
